It is currently Sat Aug 02, 2025 10:02 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 162, 163, 164, 165, 166, 167, 168 ... 568  Next
PostPosted: Sat Jul 03, 2010 6:44 pm
did a hydro pump up for a nice old fella with an indigo blue/white MK1 S :)
PostPosted: Sat Jul 03, 2010 7:36 pm
Pulled the dash out, took my CD player out to liverpool to have it repaired after it fell victim to my leaky front screen rubber :?
You're so square
Baby I don't care
PostPosted: Sat Jul 03, 2010 7:37 pm
also, went and bought some 6x9's and some wood (verrry tricky fitting large pieces of ply in a mini..) so i could knock up a boot board and possibily some speaker pods to go in the rear bins (just like nullabar express' pods)
You're so square
Baby I don't care
PostPosted: Sat Jul 03, 2010 10:08 pm
After watching Skender's GT go through some starter troubles at the Geelong Dyno day, I marched out to find that mine wouldn't start on the button either :shock: I thought Sken must have been pulling my leg!
I got a jump and took the car home and checked and excluded the battery or solenoid. So I pulled down the starter and found that the stator winding (made out of coiled 1/4" copper strap) had a fracture and had snapped. A little more high tin content soldering required, but should be fixed tomorrow...
PostPosted: Sat Jul 03, 2010 10:54 pm
Mick, did it fracture at a solder joint (dry joint) or the copper it self?
PostPosted: Sat Jul 03, 2010 10:59 pm
hahahahaha - must've been the day for it!!!
the car I did the hydro job for wouldn't start, we reckon the starter is cactus, then I went to start mine and the starter just spun like the bendix wouldn't throw
PostPosted: Sat Jul 03, 2010 11:03 pm
Spooky! :P
PostPosted: Sat Jul 03, 2010 11:11 pm
I got into my Morris this morning and when I turned the key... you guessed it, the Gemini starter worked beautifully as usual.
PostPosted: Sat Jul 03, 2010 11:24 pm
Man.. you beat me to the smart arse my starter motor works response.
So i got in my mini today and started it first try, then went for a fang.
better late than never
You're so square
Baby I don't care
PostPosted: Sun Jul 04, 2010 4:48 pm
I put a new carpet set in (thanks Trimm), and put new vinyl on the lower dash rail. Yet to do the top. Oh, and I put new vinyl wheel arch trims over the back wheel arches. The interior is looking smick now, just a few little jobs to finish off.
Ryan
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Sun Jul 04, 2010 5:15 pm
Removed the broken gear selector rubbers on the moke
"Ride hard or die trying"
PostPosted: Sun Jul 04, 2010 6:18 pm
It fractured between the starter cable terminal and the 1st stator coil.
PostPosted: Sun Jul 04, 2010 6:22 pm
Mods rock!
Work hardened?
PostPosted: Sun Jul 04, 2010 6:24 pm
Replaced my battery for a 750cca Optima , Fu$& yeah , and then drove the " Snail " to Beaufort and back
PostPosted: Sun Jul 04, 2010 6:42 pm
Installed the second engine
You're so square
Baby I don't care
