It is currently Sat Aug 02, 2025 10:06 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 163, 164, 165, 166, 167, 168, 169 ... 568  Next
PostPosted: Sun Jul 04, 2010 6:44 pm
I put the bloody freshair heater back into the 1412 wasaMatic. it ain't a great heater, but this weather it sure beats having nothing! :P
PostPosted: Sun Jul 04, 2010 11:09 pm
I finally put new shoes and cylinders on the front brakes. Took it for a test drive and it now stops in a straight line.
Why don't people believe me when I say Arianca Tan will make a come back.
PostPosted: Sun Jul 04, 2010 11:13 pm
I wiggled the valves in the head to see if they had magically swelled up to fit better in the guides...... They hadn't ..........
Sigh...
PostPosted: Mon Jul 05, 2010 7:45 am
Mods rock!
Well it is a little better than having to light a fire.
PostPosted: Mon Jul 05, 2010 4:57 pm
I got my engine ready to be lifted out :D
Rod Image
PostPosted: Mon Jul 05, 2010 5:14 pm
Fitted new front brake pads.
New brake rotors (the old ones were so much thinner than the new ones, and one was very slightly warped)
Changed a tie rod end (it was so stuffed, I feel stupid for not noticing it earlier)
New rear wheel cylinders (one was leaky)
Bled the brakes.
Fitted new tie bar rubbers.
Was going to do the lower control arm rubbers too but ran out of time.
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Mon Jul 05, 2010 6:39 pm
got it out of the garage and took it for a belt
man i should do that more often :D
ook!
69 mini k
PostPosted: Mon Jul 05, 2010 7:51 pm
Got out bid on some smithies and I know it was one of you :evil:
PostPosted: Mon Jul 05, 2010 8:04 pm
More sanding..... almost completely back to metal now!
1975 Hairy Lime/White Clubby
PostPosted: Mon Jul 05, 2010 8:58 pm
I put the new Toyota PCV valve in again, the right way round this time.
Bastard has no markings...
:x
Last edited by drmini in aust on Mon Jul 05, 2010 9:16 pm, edited 1 time in total.
PostPosted: Mon Jul 05, 2010 9:02 pm
:x
That sucks.
PostPosted: Mon Jul 05, 2010 9:38 pm
[quote="drmini in aust"]I put the new Toyota PCV valve in again, the right way round this time.
Ever heard the saying, suck it and see :lol:
PostPosted: Mon Jul 05, 2010 10:57 pm
I did, and got it wrong 1st time. :P
PostPosted: Tue Jul 06, 2010 6:25 pm
Today I,
Put a rubber strip in the bonnet channel....it cut down so many vibrations.
Went and bought new bolts for the drive flange and put them in.
Replaced the lower control arm rubbers. It is amazing how it changes the feel of the car.
Changed the upper steering column bush and fixed up the horn so that it works.
Cleans the inside.
Took it for a spin.
Ryan
Ryan Filippi
Minis In The Gong
[email protected]
PostPosted: Tue Jul 06, 2010 6:57 pm
ryan wrote:
Today I, Put a rubber strip in the bonnet channel....it cut down so many vibrations.
Ryan, did it just cut vibration at idle or throughout the rev range? Did you get rubber from Clark Rubber, if so can you remember what dimensions?
Jim :D
