It is currently Fri Aug 22, 2025 10:40 am
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
PostPosted: Thu Jul 08, 2010 6:45 pm
Mods rock!
There is a reason that they spent money and exerted effort to change the valve guide design.
PostPosted: Thu Jul 08, 2010 7:12 pm
jester99 wrote:
what if i loctite the seals down? i read a post from a while ago where someone mentioned you can loctite the seals to the tops of the guides.
I loctite my USA supplied Viton seals on, but they have a brass casing.
PostPosted: Thu Jul 08, 2010 8:34 pm
ok thanks for confirming that drmini. i wasnt sure if loctite seals rubber? :lol:
ok, so what are some suggestions if i was to use the current valve guides.
remove the cap seals, and just stick with the orings?
how much will it smoke if i just use the origonal oring setup?
Jason
PostPosted: Thu Jul 08, 2010 9:40 pm
I'd stick with the O-rings on a smallbore head if using a sporty cam.
If the guides and valves are good (preferably new) it should be fine.
PostPosted: Thu Jul 08, 2010 9:45 pm
Ok thanks kev, cheers for that.
i will remove ther cap type valve stem seals tomorrow and leave the orings there. reassemble and it all should be good.
Users browsing this forum: No registered users and 291 guests
