It is currently Fri Jul 18, 2025 9:46 am
PostPosted: Thu Jul 29, 2010 8:52 am
have a 45dcoe weber on my 1275 & can`t see anywhere to run the vaccum advance to. there are no vaccum ports on the manifold.
was thinking i might have to drill & tap the manifold unless anyone has another idea.
all help appreciated
jayson
PostPosted: Thu Jul 29, 2010 9:00 am
Forget the vacuum advance with a Weber.
You won't get enough decent negative pressure for it to work.
PostPosted: Thu Jul 29, 2010 9:19 am
ah ok, thanks for that
PostPosted: Sun Aug 01, 2010 6:28 pm
Yeah, ditch it. Real Men don't do vac advance!
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
PostPosted: Sun Aug 01, 2010 6:32 pm
Vacuum advance is a fuel economy device. A weber isn't. 8)
PostPosted: Sun Aug 01, 2010 6:44 pm
Show me a performance engine that uses vac advance..
Alfa twincam? Nope-
Fiat/Lancia twincam? Nope-
Cooper S? Nope-
If you have a decent duration cam in your A series, vac advance will do SFA anyway, even with an SU carb. So saith the cam grinder man with the engine dyno. :wink:
PostPosted: Mon Aug 02, 2010 9:18 am
yep no worries.
think the weber is too big for my motor so going to an su anyway.
thanks for the advice all the same
PostPosted: Mon Aug 02, 2010 9:30 am
why not try some smaller chokes in it?
PostPosted: Mon Aug 02, 2010 8:35 pm
Vac advance will significantly improve your fuel consumption - which is what its there for. If you're happy paying 30% more for fuel each week (the effect it had on my commute) then don't fit one.
Webers can be easily set up to return 30 mpg on an S which is not too shabby.
Cheers, Ian
