It is currently Sun Jun 22, 2025 11:24 pm
Post new topic Reply to topic  [ 353 posts ]  Go to page Previous  1 ... 12, 13, 14, 15, 16, 17, 18 ... 24  Next
PostPosted: Tue Jul 20, 2010 11:17 pm
hallsey wrote:
just used mini clutch master cylinder, clutch is a bit
heavy but certainly bearable
So you are using the standard slave that came with the Starlet engine? 3/4" slave?
-Alan
PostPosted: Thu Jul 22, 2010 7:35 pm
yeah Al
yep just the standard toyota slave and mini dual circuit
master, it's firm but bearable
Cheers Hallsey
PostPosted: Thu Jul 22, 2010 7:59 pm
Yeee Haa
Had the engineer back today to check over everything.
OMG he was more excited than me, we went over the car for about
two hours and he's extremely pleased with everthing.
So now the fun part begins, swapping everthing over to the good shell.
Still a lot of work involved, need to paint everything,cut the inner gaurds,
fit everything up.
Then it goes for brake and noise tests and then he signs her off
He had a huge grin and said he cant wait to drive it for the tests,so there
is gunna be quite a few nights in the shed
Cheers Hallsey
PostPosted: Thu Jul 22, 2010 8:26 pm
Great stuff Hallsey.
What does he do for the test drive? Where?
Madmorrie
PostPosted: Thu Jul 22, 2010 9:04 pm
Congrats so much, Hallsey!
You've done it the right way IMO. Mine would have been so much easier and neater the 2nd time around!
Good luck, I'll have to come around again one day so we can go for another drive up arthur's seat! :D
-James.
Toyota 4EFTE Powered Minivan.
PostPosted: Wed Aug 04, 2010 8:08 pm
Hi guys sorry for the delay but i've been busy
Madmorrie : I dont know where or when ,to tell you the
truth i was so excited i didnt ask :oops:
James: wont be long mate, a few months and we'll be cruising together
this is how the car looked when the engineer came to look at it
Then it was into stripping the car, first the motor out
Then strip the front and rear ends out
Just the bare shell left and more room in yhe shed
Simply red straight after my last drive with the A series and ready
for the transplant
Out with the A series
In with the subframe
And finally with the 4EFTE
Everything will be test fitted and then pulled out again and painted
when i'm happy with everthing
PostPosted: Wed Aug 04, 2010 8:13 pm
That looks awesome, love how the colour matches,
Will make an awesome street sleeper.
Simplify and add lightness
PostPosted: Wed Aug 04, 2010 8:17 pm
Hope so joe, i've taken 2 weeks off work to make a dint in the
transplant
Hope to have a fair bit done before i go back to work
Cheers Hallsey
PostPosted: Wed Aug 04, 2010 8:56 pm
Awesome work there Hallsey.
I'm thinking the only way my stuff will get done is if I take time off to do it as well. Good luck with it all, it's looking great!
Madmorrie
PostPosted: Wed Aug 04, 2010 9:05 pm
you must be so excited! :D :D :D
I know I am just looking at the pics!
On the home straight :wink:
-James.
PostPosted: Wed Aug 04, 2010 9:07 pm
good to see the van in the garage too! :wink:
-James.
PostPosted: Wed Aug 04, 2010 9:31 pm
Thanks guys
yeah i'm pretty pumped, the light is at the end of the tunnel
Cheers Hallsey
PostPosted: Mon Aug 09, 2010 2:18 pm
Hallsey,
Well done Ol' Sock!
Now, tell me you are going to paint or powdercoat that subframe before it goes into Simply Red??
Tricky
PostPosted: Tue Aug 10, 2010 9:00 pm
G'day Tricky ol'son
Dont you like the rustic look ? :D
The subframe will be painted,hopefully in the next couple of weeks
I've been busy doing all the fiddly things
Been putting nutserts in, mainly in the engine bay, mostly brake line
brackets
Cut the holes for the shift cables and wiring
Fitted the airbox
The engineer wanted all the sharp edges gone from when i
cut all the inner gaurds.
So some 6mm rod bent into shape then welded into place
Heres a photo(not a very good one :oops: ) with the rod
in place on the front panel.
This is from the engine bay looking out the front
The same spot from the top. this is the cutout for the radiator
Cheers Hallsey
PostPosted: Tue Aug 10, 2010 10:59 pm
Top work mate. Frank has recommended that to me several times, "Just put some rod on there to strengthen the edge and I'll be happy with it", I have done it on the back of the subframe, and will do it on panel edges as well.
I finally cracked it with the Valiant situation on the weekend and went in to the shed for some quality Morris time, got most of the fuel lines run in a productive few hours. Decided to just and crack on with it when work allows (and ignore the other cars), hopefully will have it running for xmas.
Madmorrie
Users browsing this forum: No registered users and 21 guests
