It is currently Wed Jul 30, 2025 2:23 am
PostPosted: Tue Aug 10, 2010 8:08 pm
As above, my HIF44 doesn't quite fit on the minispares inlet - the fuel bowl is just hitting the firewall where the hole for the speedo etc is, probably only needs 1/4" more clearance.. is this normal? Do I just get the BFH out onto the firewall? Should I be running a thinner spacer?
tim
PostPosted: Tue Aug 10, 2010 8:12 pm
I run a 1/4" spacer on mine and it clears. It did not fit with the original thick black spacer.
Mods rock!
There was one version that was simply the wrong angle and other than the BFH there is not much you can do.
I have used a few of these, with the best all round mini carb (ducks for cover) the HIF44. I fit them with no spacer and while it all fits, it is necessary to fit the carb to the manifold and then put the manifold on the head.
<EDIT> Putting one on anthing other than a 1275 could reduce any clearance that you might otherwise have. The 1275 block is 3/8" (10mm) taller than all others.
PostPosted: Tue Aug 10, 2010 8:28 pm
It's on a 1275, with 1/2" spacer... where does one find a 1/4" spacer?
Thanks!
tim
PostPosted: Tue Aug 10, 2010 8:41 pm
Get someone to machine it thinner... :wink:
PostPosted: Tue Aug 10, 2010 8:43 pm
I got my spacer from www.minispares.com. My manifold is the older style that is flat across the top of the heater pipe also on a 1275. I cut my studs down to the minimum length and can just get the carb on with manifold fitted.
PostPosted: Tue Aug 10, 2010 9:33 pm
sorry off the bat for hijacking this post,
i've got that same manifold... does anyone actually bother hooking up the water to the heating pipes and run the coolant through this manifold?
trying to sort some tuning issues and wondering if the heated manifold would help or if it's just one of those pommy things.
 Post subject: Hif44
PostPosted: Tue Aug 10, 2010 10:20 pm
If your HIF44 will not fit on your car you should sell it to me and buy something that will fit. I am looking for 1.
"Let us remove your "SHORTS"
PostPosted: Tue Aug 10, 2010 11:21 pm
I was told today by someone that it can make a big difference removing flat spots.... ? I've got mine hooked up fwiw.
Convertible Mini, sorry mate, the BFH got to the firewall before I had a chance to check this thread again :P
tim
PostPosted: Wed Aug 11, 2010 3:35 am
As Kevin suggests mill the spacer thinner...which is what I did and round filed the Mini Spares intake to allow the throttle quadrant to rotate without fear of interference.
Image[/img]
PostPosted: Wed Aug 11, 2010 7:36 am
Mods rock!
It can help the tinest bit with a feeling a smoothness in accelerating. It will help with economy.
I don't bother with them.
PostPosted: Wed Aug 11, 2010 11:24 am
It makes a big difference to carb icing on a long run in winter. It gets quite exciting when your throttle freezes wide open and you run up behind a slower vehicle.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
