It is currently Mon Aug 18, 2025 8:43 pm
Post new topic Reply to topic  [ 52 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Fri Aug 13, 2010 7:04 pm
when i get her back i'll have a look see.
get back to you .
PostPosted: Fri Aug 13, 2010 7:20 pm
I think I got mine from Mini Mania in the US?
PostPosted: Fri Aug 13, 2010 7:55 pm
Give Ash some flowers Nick .
Hanra wrote:
1018cc wrote:
I'll measure it tonight because my car is still in pieces anyway, so easy access :lol:
Did you get a chance to meausure the filter thickness mate?
They are 14mm thick so looks like the 24mm I thought was a bit small. So there is 28mm of filter thickness over the whole diameter.
PostPosted: Fri Aug 13, 2010 8:02 pm
Righteo, thanks for that mate. Im about 2mm shy.... I think the bench grinder can fix that!!! Or Ill just trim the filter i bit to clear the stub stack.
PostPosted: Fri Aug 13, 2010 8:09 pm
So are the bases you have the right diameter?
Keep in mind that if you are thinking that, these filters are meant to be wedged together between two plates, as shown in the full kit. I don't think you could just plug it in to your ramflow filter base & have it work.
PostPosted: Fri Aug 13, 2010 8:12 pm
Yeah yeah, Ill end up buying the full kit as you have. But I need to be able to clear the stub stack. I was kind of assuming the bases would all be about the same size...?
PostPosted: Fri Aug 13, 2010 8:18 pm
The inside edge of my base is a perfect fit around the air filter, no gaps etc. I'd compare your bases against the outside diameter of the air filter as listed on the K&N site, not from my original measurements. That should give you a pretty good idea.
Users browsing this forum: No registered users and 327 guests
