It is currently Tue Jul 29, 2025 9:07 pm
PostPosted: Wed Sep 08, 2010 9:49 pm
Mods rock!
The guides these days don't normally need reaming after fitting but the seats will need re-cutting.
PostPosted: Wed Sep 08, 2010 9:58 pm
I beg to differ, if you use the bronze guides.
They close down in size a bit when fitted.
They tend to close even more after a heat cycle or two.
If/when they grab a valve, you will be real sorry... $$S wise. Ask some of the racers out there.
The bronze ones definitely need reaming (I use a new 9/32" solid reamer) after fitting. Then recut the seats.
PostPosted: Wed Sep 08, 2010 10:27 pm
[/quote]Mate I spent the 1st 12 weeks of my apprenticeship filing and chipping steel. I have the callouses to prove it.
Did teach me how to file flat though. :wink:[/quote]
I'm guessing a railway apprentice Kev. as i did the same
PostPosted: Wed Sep 08, 2010 10:30 pm
I'm guessing a railway apprentice Kev. as i did the same[/quote]
Check. :wink: NSWGR, they still had some steam locos working way back then.
PostPosted: Wed Sep 08, 2010 10:35 pm
Check. :wink: NSWGR, they still had some steam locos working way back then.[/quote]
Yep it's a wonder that we're still kicking with all that asbestos lagging on those things
PostPosted: Thu Sep 09, 2010 10:07 am
So cast-iron guides don't shrink at all from the interference fit?? Seems at odds from what I was always told, which is that guides ALWAYS need reaming!
Does anyone cut their own valve seats, and if so could you point me towards a tool I could buy/borrow? Or is it not worth it and I should just head off to the machine shop instead?
Jacob
PostPosted: Thu Sep 09, 2010 3:44 pm
Cast iron guides don't shrink, I always try the solid reamer in them but nothing comes out.
If you want the best of both worlds, get your old guides K-lined.
These are a thin bronze liner that is fitted into your (machined out) old guides.
Costs around $140+ to get them done in Sydney.
I gave up cutting valve seats by hand years ago. I fit new guides, then head for Graham Russell.. 8)
[edit] typo
Last edited by drmini in aust on Thu Sep 09, 2010 4:22 pm, edited 1 time in total.
PostPosted: Thu Sep 09, 2010 4:18 pm
Mods rock!
Jacob
I always check the guides but in the last 10 or so years never had any that needed reaming.
I have a few Neway Valve seat cutters but they are a bit pricey if your only doing a few heads. Repco used to (still have?) a grinding type tool, a place I used to work at had one but I thought it crap as the ginding wheels where the wrong material and wouldn't hold there shape / angle, so the seat face ended up rounded rather than flat.
PostPosted: Thu Sep 09, 2010 8:43 pm
The stones neen trimming to keem them at the correct angle/shape
I have hand seat-cutters here but i only use them as a rough guide/start to get the seats all sitting in the right spot/height,,, then have them stoned, blued & sucked :-) sounds kinda kinky hey? ;-)
Users browsing this forum: fuzzy-hair-man and 42 guests
