It is currently Mon Jul 21, 2025 9:28 pm
PostPosted: Tue Sep 14, 2010 12:11 pm
Its not a clubby number, its a typo, 7G2S1 could be YG2S1 8)
Edit!
Ignore that I'm talking rubbish, looked at the pics and it is a bit wierd! :lol:
Sir Alec! we are not worthy!
PostPosted: Tue Sep 14, 2010 12:21 pm
You're right, the typo is 7G2S1, should read YG2S7
I reckon a clubby with a roundy front graft
It's no way a 68!
PostPosted: Tue Sep 14, 2010 12:23 pm
B#gger, but what about the doors!! :x
PostPosted: Tue Sep 14, 2010 1:12 pm
hiya,
Yep, the rear lights could have been changed, but surely not the doors?
Definite typo!
I suspect it was once a roundy bare shell and everything clubby has gone into it. Including engine and id perhaps too....
Topical type of discussion at the moment :D
cheers! jon
PostPosted: Tue Sep 14, 2010 5:36 pm
It is a 69 Mini K. YG2S1.
PostPosted: Tue Sep 14, 2010 7:36 pm
Michael i reckon just swap the radiator shroud with your clubman one. Save a lot of hassels. The person doing the blueslip wont know its not the original inner guard. And it is representing the car for what it really is, an LS
Goodluck
Brenton
PostPosted: Tue Sep 14, 2010 7:38 pm
It's not that easy, they are a different shape.
PostPosted: Tue Sep 14, 2010 9:50 pm
Once again you are correct.
Well an update is that I have removed both top panels and am now cleaning up the Clubbie panel ready to reshape and weld back into place tommorrow.
So all good.
Car keeps its original number and should therefore make the registration process easier and the Mini K has been placed into the dead Mini K register.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Tue Sep 14, 2010 10:22 pm
"They" don't care. I had a MkII S that turned into a Clubman overnight.. I think maybe because the engine may have been from a GT. Never worked out why ... the car had the same numbers for years before the computer changed its mind. Took all sorts of hassles to get the S ID re-instated.
My Mk I has a UK chassis plate ... invalid, removable (held on with phillips head screws), has a UK body number .. invalid, plate welded to removable cross member.... so they looked around and decided to settle on the the "FE" number....
Not recorded anywhere else but Rego is happy.
Just take the car in, show them what you've done and ask what they want to do. As long as they have a choice . ie there is a number attached permanently to the shell they will be happy.
Cheers, Ian
PostPosted: Tue Sep 14, 2010 10:50 pm
I agree.
I have registered a few minis which require blue slips to establish identity and usually I have to point out the number which should be used for the rego as they have no idea what to look for as the cars dont have a VIN like modern cars.
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Wed Sep 15, 2010 7:32 am
In recent years I've founf the blue slip inspectors in NSW want to use the numbers on the rad shroud (which are correct, for 1969> Minis) for earlier ones too (incorrect). :roll:
It pays to keep old rego papers if available.
PostPosted: Wed Sep 15, 2010 7:44 am
Mods rock!
Yes. The Blue Slip Guys are required to use an on-line system that among other things, shows them where to find things like VIN (body nos) and engine nos etc for all(?) cars and for the Mini, it only shows the radiator shroud as per late cars. It does not show the firewall location for the earlier cars.
PostPosted: Wed Sep 15, 2010 9:02 pm
Well I have done the deed. :)
First I reshaped the Clubman panel to the shape of a round nose.
Then welded it into place
Ground down the welds and finished with primer.
Probably would have been much quicker and easier prior to fitting the inner panel to the car.
So another job finished.
Whats next?
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Wed Sep 15, 2010 9:14 pm
youre a machine michael! :D
I love watching your progress!
mooo, I'm a pig!
PostPosted: Wed Sep 15, 2010 9:17 pm
When do we get to see some progress on your project?
:lol: :lol: :lol:
1969 Cooper "S"
1967 Mini Deluxe
Users browsing this forum: BBY755, watsupskip and 66 guests
