It is currently Thu Jun 19, 2025 11:36 pm
Post new topic Reply to topic  [ 55 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Mon Aug 30, 2010 11:36 am
I've always felt that straight out the back exhausts sound a little raspier than side exit. I figured its because I could theoretically look up the pipe and straight into the back of the extractors.
I've not compared identical muffler setups (straight rc40/side exit rc40) side by side however to back it up, so I might be mistaken.
PostPosted: Mon Aug 30, 2010 11:51 am
CARTER_GT wrote:
the only problem with webers is the insurance.
Not sure which insurer you're referring to but I've been with shannons for 7 years and have an extensive modifications list. My premium did not change much going from the 1152cc to 1330cc, Weber, S brakes and all.
IMHO Anyone on here with a mini and not with shannons are really missing out...
PostPosted: Mon Aug 30, 2010 11:52 am
I've just done this, They are both the same as far as I could tell performance wise and sound. Only difference wis that side exit is less smellier, plus it is difficult to achieve "sleeper look" with a center exhaust :wink:
PostPosted: Tue Sep 21, 2010 5:23 am
I'm thinking a medium bore LCB will do the trick. Anyone selling or know where to pick up a good deal? The Perry's will be for sale.
PostPosted: Tue Sep 21, 2010 7:21 pm
Here in NSW I've found Karcraft's prices for a med bore Maniflow pretty good.
However I hear the Chinese knockoffs are better made- at least their flanges are flat! (unlike both my Maniflows were) :roll: Not sure who the agents are...
PostPosted: Wed Sep 22, 2010 8:29 am
Doc, is this what I'm looking for from Karcraft?
Part No Description Price Each
C-AEG365 EXTRACTORS - LCB - MINI (MANIFLOW UK) $159.60
bore size is 1 3/4'' ID'. Postage to 2285 $16.00.
PostPosted: Wed Sep 22, 2010 7:49 pm
Description sounds right, but it's a KC102 in my catalog (feb 2010).
Yes the bore of these is 1-3/4, I just had a 1-3/4 OD pipe (what you have now) pushed inside and clamped when I ran the RC40 muffler.
On my 1360 or 1412 I use a 2" OD pipe slipped over the outside, but that is too big for your 1293 and Tighe 104 cam.
Check the flanges are flat before you bolt it in. They often are not, and the middle one will then leak.
I assemble them onto an old head (no gasket) then go round with a .002" feeler gauge. If it goes in anywhere I grind/file the flange until it doesn't.
PostPosted: Wed Sep 22, 2010 10:05 pm
slinkey inc wrote:
They must have changed more recently.
not fussed about modifications as long as they were illegal.
gee must have been a good company :lol:
bought my lcb in 304 ss from england some months back for a good deal less. Sell for 600 here but think mine were 300-ish :?:
PostPosted: Wed Sep 22, 2010 10:11 pm
Also check that the flanged are same thickness as your intake manifold flanges. If not and one is thicker than the other you won't get a good seal
PostPosted: Wed Sep 22, 2010 10:12 pm
If they are not the same (often the case) make some thick stepped washers. I will machine you some cheap if you give me the thicknesses.
PostPosted: Wed Sep 22, 2010 10:18 pm
i used my origonal non-stepped washers, and ground them down on one side on my bench grinder until the fit was nice. as i didnt have to take a massive amount off them to make them sit square it worked for me.
PostPosted: Wed Sep 22, 2010 10:37 pm
Well my 5.5inch RE7 manifold was nearly the thickness of the washer different...
PostPosted: Wed Sep 22, 2010 11:45 pm
This space for rent
Bit of a late comment on this one, but I can 110% vouch for the improved note by changing from Perry 3-1's to a Maniflow 1-3/4" LCB (mine are the Chinese knockoff, and damn good they are too).
With an RC40 single box, the Perry's sounded good, but the LCBs are just sensational -- much, much more musical in the note. It's like there are two notes playing in harmony, rather than one... which kinda makes sense when you look at how the LCBs are set up ;)
There was probably 5-7 HP in the LCBs on my warm 1152, too... as an added bonus :lol:
PostPosted: Thu Sep 23, 2010 3:38 am
These are the options Doc...
August Catalogue...
EXTRACTORS - 3 INT0 1 - MINI (MANIFLOW UK)(RACE) KC103
EXTRACTORS - 3 INT0 1 - MINI (SUPA PIPE) KC308
EXTRACTORS - FREE FLOW - MINI KC307
EXTRACTORS - FREE FLOW - MINI (MANIFLOW UK) C-STR816
EXTRACTORS - LCB - MINI KC314
EXTRACTORS - LCB - MINI (MANIFLOW UK) C-AEG365 2
PostPosted: Thu Sep 23, 2010 3:52 am
...and what do y'all think the Perry's are worth? I'll stick em on the for sale section when I get back from Canada.
