Lillee wrote:
I'm not fiddling with jets, I'm working out the best flow filter which subsequently requires changing of jetting
How goes the search? any reccomendations so far?
dr mini in aust wrote:
Single HIF44 on a good manifold works well, so do twins (preferable HS4s). Twins do need a bit more TLC. Having said that, I run a Dellorto 45 because I can jet it then forget it. But a single HS6 or HIF44 SU on a good manifold does give more midrange torque.
So the single hs6/hif44 will give better torque, but dellorto/webber is better for the set 'n' forgrt types? Is there a world of difference in induction noise? never been in a mini with a webber or dellorto.
Lockie91 wrote:
yep, the webber i put on little red last year, sucked through a 20litre tank in half the time, but the enhanced power range from the 1.5 SU was awesome.. even my 1100 loved the webber better, but my pocket didn't.. hate to think how much this 1380 big bore is going to suck with the big lumpy cam, enlarged manifold, head, and even bigger dellorto than that webber...
That tells me either excessive use of the right foot (very likely) or poor tuning or both.
