It is currently Sun Aug 10, 2025 6:12 pm
 Post subject: leyland clubman wiring?
PostPosted: Sun Sep 26, 2010 4:02 pm
Hi just wiring my 63 with a leyland clubman harnesss and have been going through all wiring diagrams that i have(3 workshop manuals and downloads from here) and was wondering if there is anywhere i can download a wiring diagram for the leyland mainly to find wire colours and trace colours. I am using the leyland harness because i have fitted a pulsar dizzy gemini starter and alternator and hoped the harness might have been easier(and cheaper) than getting sparky to do whole new one THANKS
Darren
00 triton d/cab
55 chev(oversize moneybox)
1963 850 (roundie)
77 clubby
95 zxr 750 + toys!!
PostPosted: Sun Sep 26, 2010 5:26 pm
Mods rock!
Wiring colours are the same across the Mini range.
PostPosted: Sun Sep 26, 2010 5:34 pm
ok thanks ill have to keep going through them some colour combinations i cant find in any of the morris wiring diagrams
Darren
00 triton d/cab
1963 850 (roundie)
77 clubby
95 zxr 750 + toys!!
PostPosted: Sun Sep 26, 2010 5:52 pm
Mods rock!
OK, if it helps;-
Black Earth (to body)
Brown Live from battery (direct)
Purple Live from battery via fuse
White Live via Igntion Switch (no fuse)
Green Live via Ignition Switch and fuse
Red Park Lamps
Blue Headlights
Those are the 'basic' colours. From these trace colours are added to further define what the circuit is for
PostPosted: Sun Sep 26, 2010 7:08 pm
thanks it's not going to bad just having trouble with a couple now mainly blue/yellow and red/yellow ill undo some of the harness tape maybe it has been changed
Darren
00 triton d/cab
1963 850 (roundie)
77 clubby
95 zxr 750 + toys!!
PostPosted: Sun Sep 26, 2010 7:25 pm
It's probably worth undoing anyway to check if someone has added or joined wires. You find all sorts of horrors from previous owners handiwork.
PostPosted: Sun Sep 26, 2010 7:28 pm
Mods rock!
Sure they are not Blue / White and Red / White?
