It is currently Wed Jun 25, 2025 9:35 pm
PostPosted: Tue Sep 28, 2010 10:23 pm
Just use decent rods.
There in lays the key to a good weld :wink:
spot on doc
PostPosted: Wed Sep 29, 2010 12:15 am
thanks doc, ill look for that brand stick. I dont want to spend heaps of cash, and i just want to get the job done to pass rego, at this stage im not hugely fussed on how good it looks.
im pressed for time on the space i have, so im trying to get as much done as possible as quickly as possible. I could take the whole car to a panel beaters, but ill do that later as it will cost a fair bit, and theres a bit more work than the floor pans.
PostPosted: Wed Sep 29, 2010 8:35 am
spot on doc
Ooooh ....so thats why my 26 year old rods don't work that well ????? :roll:
David L
PostPosted: Wed Sep 29, 2010 8:44 am
spot on doc
Stick em loose in the oven at 150C for 30 mins or more to dry out. You may be surprised at the difference it makes.
Seriously though, I find the WIA 12Ps great. They strike easy, run smooth and are fine for out of position work too.
But having said that, stick welding is pretty poor on 1.6mm thickness or less, compared to MIG. It won't make strawberry jam out of pigsh!t. :lol:
PostPosted: Wed Sep 29, 2010 9:09 am
... but not if they're cellulose!
PostPosted: Wed Sep 29, 2010 9:41 am
is the heat going to melt the edge of the steel.
at this stage if its just going to put a big bead along the edge ill angle grind it back, get someone to clean it up later.
for cost/time the other option for me is to hire one from the tool hire place.
PostPosted: Wed Sep 29, 2010 9:48 am
Stick welding gives wider penetration than MIG does, yes it'll melt the edges of the steel. If it's not melted, technically it's not a weld.
PostPosted: Thu Sep 30, 2010 11:24 am
i understand that, but is it going to be too hot and melt too much away.
for the floorpan and other general purpose im taking it with a little skill using a stick its will be suitable.
PostPosted: Thu Sep 30, 2010 11:40 am
I would practice on some scrap thin sheet first. Stick welding sheet metal is an acquired art... :wink:
PostPosted: Thu Sep 30, 2010 7:28 pm
jeez a just re read what i wrote and what bad grammar.
I will do some practice first. I have also used one before. But not for a loooooooong time.
Users browsing this forum: stewartp and 88 guests
