It is currently Fri Aug 08, 2025 12:57 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 183, 184, 185, 186, 187, 188, 189 ... 568  Next
PostPosted: Sat Oct 02, 2010 8:41 am
Stripped the LHS rear windows in the Estate (I'd done the RHS earlier) only to find more rust & shagged window sliding channels - bum.
Bought paint, primer etc for the repaint - expensive but worth it.
PostPosted: Sat Oct 02, 2010 2:03 pm
Flowtested the 12G940 head (ex-race) off my 1360 at GR's.
The inlet flowed 120cfm @ .450" lift and 122cfm @ .500" lift. (valve lift in this motor is .493").
Interestingly, my 1412 stroker's head with the same sized 35.6mm inlets, only flowed 116CFM max @ .450" lift, but up to .300" lift it beat the race head. One of the benefits of slightly smaller ports... :wink:
PostPosted: Sat Oct 02, 2010 5:06 pm
I'm collecting a bare shell next weekend. It is painted so I have to get it onto a tilt-tray and off again, then through my yard to the shed without damage.
So I made up some trolley-subframes. They are dodgy old subframes with Supercheap fridge trolley wheels welded on. The fronts pivot so I can steer it.
It was fun to use the welder again. Sadly I'm still a no-talent schmuck :( but they'll do the job.
Pushed the moke around in the shed and noticed a little brown piddle and a little green piddle on the floor. She still needs some TLC.
M
PostPosted: Sat Oct 02, 2010 6:51 pm
Installed special tuning spark plugs :wink:
PostPosted: Sat Oct 02, 2010 7:11 pm
Covered it in collingwood stuff and cruised around town waving at people
PostPosted: Sat Oct 02, 2010 9:22 pm
Skip arrived late but this gave me time to organized on what I wanted out of the garage around Marcia I have plenty of space around her now. After I filler the 6 meter skip (only ordered a 3) :lol: I got the battery + tucked up and the the Exhaust completed. Also got the Go peddle cable spot on.
Productive day which should give me the chance to start her up tomorrow
PostPosted: Sat Oct 02, 2010 9:36 pm
crawled underneath to see where all that exhaust noise was coming from. Up for a new muffler now
PostPosted: Sat Oct 02, 2010 10:00 pm
That's what you get for hammering it around Tassie :)
PostPosted: Sat Oct 02, 2010 11:01 pm
Example of hammering. :) :lol: :lol:
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sun Oct 03, 2010 5:55 pm
had a test fit with my seats today-been 18 months or so since they've been in, and i wanted a look-see at how'd they look :roll: :lol: ! The husband bought me a set of really cool seat covers (that with a heap of ummm, adjusting!) will look freakin awesome!
Now, if someone could tell me which safe spot i put the seat bolts in , i will be stoked :roll: :evil: !
Cheers, Kim :-)
**purple '68 deluxe!**
***FINALLY wearing number plates----yeaaaaaah baby! ***
PostPosted: Sun Oct 03, 2010 9:10 pm
Fitted new rubber seals to the two front quarter windows . now I know why people complain about these PITA seals :)
PostPosted: Sun Oct 03, 2010 9:17 pm
Fitted up and testing the wiring harness - am happy as, no faults at all, all lights working exactly as intended :D
Cut the hole that had been welded up (for povo-pack 4-sync magic wand gearchange)
fitted seat brackets to crossmember
installed door rubbers
drank beer
admired work :lol:
Jacob
PostPosted: Sun Oct 03, 2010 9:23 pm
Decked another .012" off the 1360's ex-race head. C/R is now about 10.6:1, will be fine with the RE282 cam.
Last edited by drmini in aust on Mon Oct 04, 2010 12:54 pm, edited 1 time in total.
PostPosted: Sun Oct 03, 2010 10:22 pm
NAV wrote:
Lillee wrote:
jester99 wrote:
checked for damage to the sump guard after being pulled over by the police last night and asked to drive up a gutter, causing my sump guard to scrape. :evil:
What was that all about???
Ditto, thats a really odd request.
yep wtf, no fine could amount to that, id be telling him where to get off.
PostPosted: Mon Oct 04, 2010 8:47 pm
Put in the Windscreen into Marcia. Never done it before & not wanting to do it again but I did find another use for Chinese takeaway containers :lol: Went and started putting in the locking strip and it was way short :twisted:
Gave up on that and turned back to getting Marcia moving again. Realized I hadn't adjust the tappets and couldn't move the crank :roll: Bolts holing the Oil filter were to long so just spaced the out with nuts :wink: Water in the rad and I hadn't tightened the Temperature sender. Got the wife down to turn the key to prime the pump and all good. As the fuel tank has a leak around the sender unit I extended the pipe to the fuel can and guess what I had the Fuel pump around the wrong was and was blowing bubbles in the can. Fixed that and tried it again and Battery flat. Ow Please :twisted:
I hate Irritations
Try again tomorrow
