It is currently Fri Aug 22, 2025 10:32 pm
Post new topic Reply to topic  [ 88 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Thu Oct 14, 2010 8:51 am
Well done Rod, any news from the perpetrators :x
PostPosted: Thu Oct 14, 2010 4:09 pm
According the the transport company web site where you can track and trace your parcel, it's not yet been received by the addressee - I've emailed the freight company to find out where it is.
Better not be sitting at their depot in Lara :x
More to follow.
Rod Image
PostPosted: Fri Oct 15, 2010 8:01 am
At least now you know the job will be done right mate!!
Yell out if you need a hand at any stage.
Speaking of letdowns....
The plasterer said he'd be round Tuesday morn to check out the studio ceiling job and never fronted!!!!! :evil:
Jarrod and I plastered the roof of the studio ourselves yesterday. Job's now done, job's done right and we saved a fortune to boot. :D
Rod.
______________________________
'63 Morris 850 (Old Secondhand CAR)
PostPosted: Fri Oct 15, 2010 5:00 pm
You want a job done, you do it yourself :) (AND save yourself a heap of moolah)
Cheers for the offer Quickie - I'll take you up on the offer when it's all about to be put back together - if I may.
Still unsure if I should get a new double row timing chain after all, the existing one's not done too much work has it. Are you able to lay your hands on that spare one you have Rod so I can compare the two?
Rod Image
PostPosted: Sat Oct 16, 2010 8:20 am
Yep I know where the new chain is. It's the sprockets that are MIA.........
Rod.
PostPosted: Sat Oct 16, 2010 9:22 pm
One of the jobs I intend to do with the block that's at the engineers at the moment is to change over the oil filter to a spin on type. It's an easy job to do isn't it?? My only thought is joining the feed pipe to the block near the sensor - I don't know thread sizes and so on but surely it's possible. I read about it somewhere and I think the only hassle is having to bend the feed pipe a little bit.
Rod Image
PostPosted: Sat Oct 16, 2010 9:30 pm
Block connection is 5/8-18 UNF.
The standard pipe will fit with a little persuasion, or why not use some Pirtek MPH-08 hose (500psi) and barb fittings-
PostPosted: Sun Oct 17, 2010 12:51 pm
Hmm....impressive, and 500 PSI....that's not too shabby at all Doc :)
Rod Image
PostPosted: Sun Oct 17, 2010 6:36 pm
Milatsmadmini
it looks pretty hot as well ;)
PostPosted: Mon Aug 15, 2011 5:29 pm
Well.......here we are......back to this thread........FINALLY ready to rebuild my engine and get Ribena back on the road.
Question.......new pistons didn't come with new cir-clips. Should they have?
Rod Image
PostPosted: Mon Aug 15, 2011 5:39 pm
YES!!!!!!!!!!
Always....
When fitting circlips, always put the sharp edge OUTwards... :wink:
PostPosted: Tue Aug 16, 2011 8:45 am
Thanks doc :)
Rod Image
PostPosted: Tue Aug 16, 2011 9:20 am
circlips are often stuck inside a plastic bag , stickytaped to the inside of the box that the pistons came in... maybe?
PostPosted: Tue Aug 16, 2011 9:49 am
... or else the bag is just shoved inside one of the pistons... so the engine reconditioning shop can lose them on the floor.. yeah it happens, often!
PostPosted: Wed Aug 17, 2011 11:44 pm
If you haven't sorted a spin on filter yet, Ive been gearing up to make some filter mounts that fit a Z9 and mount to the standard mounting points and oil pathways.
The benefit is the Z9 has the check valve in the filter, is cheaper (as its used on just about every falcon) and most importantly to me at least there are much higher quality performance ones available if you so desire.
Edit: Got my valves mixed up :oops:
Users browsing this forum: Phil 850 and 316 guests
