It is currently Sat Jul 19, 2025 4:42 am
PostPosted: Thu Oct 14, 2010 5:42 pm
So whats Kellogs Nutri Grain got to do with octane booster? :P
PostPosted: Thu Oct 14, 2010 9:20 pm
Basic Aus fuel is basically toluene (paint thinners:). There are legislated min and max percentages basically because of the effect it has on fuel lines/rubber components. Too little and they go brittle, too much and they go soggy. Either way you risk fires. Don't know if anyone remembers the incident where one tanker load of high T fuel from Singapore caused a rash of under bonnet fires in NZ a few years ago.. :(
Benzene is an excellent octane enhancer - unfortunately its not so good on the human body; alcohol works well too.
Cheers, Ian
PostPosted: Thu Oct 14, 2010 9:23 pm
Cheers, Ian
This explains why my fuel disappears without driving the car... damned evaporation from the vented tanks. :evil:
PostPosted: Thu Oct 14, 2010 9:43 pm
Tomboss Breweros
Last tow to Hay i tried the Wynns octane booster in my Outback. The Outback has poor economy on unleaded and very good economy on PULP when towing. The booster with 98 PULP was no better than unleaded. It may have been a dud batch of PULP and the additive possibly made no difference.
Either way, i got it free and i won't ever buy any.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Thu Oct 14, 2010 9:57 pm
ti anser one of your original questions a UNIT is anyone who belives that theese producs will actually noticably work
PostPosted: Thu Oct 14, 2010 10:14 pm
acetone can't be good for the lines
does anyone get the feeling these products may work in theory by lifting the octane rating on paper, but really hinder the burning of the fuel in the chamber due to separation of the mixture via different burning, atomizing & flash point?
does the "normal" fuel ignite & then set off the additives resulting in a longer burn due to a higher igniting temp?(probably not as the spark would be hotter). how does the "after burn" compare in release of energy?
From some what I've been reading people often can't notice the difference, or if they can is often 50/50 good or bad. Just seems odd so many people can't notice the difference. Perhaps peoples time & money is better spent trying to achieve a better fuel atomization using parts over additives?
end of rant
PostPosted: Thu Oct 14, 2010 11:17 pm
& then there`s the Specific Density of each of the different fuel (s)
PostPosted: Fri Oct 15, 2010 8:59 am
Yes. :D
It helps to know what the fuel is before you start chucking things in to "improve" it. :lol:
PostPosted: Fri Oct 15, 2010 8:05 pm
I knew octanen was mentioned recently
http://www.ausmini.com/forums/viewtopic ... ght=vizard
http://www.youtube.com/watch?v=CWwCtT_CwYQ
PostPosted: Sat Oct 16, 2010 1:06 pm
I've used octane booster. It made a difference. :o When you don't use a vehicle very often, given we all know that the octane additives are the first things to evaporate, it can mean the difference between running sweetly or pinging... That's from experience - I ran the car one day, it pinged. I put in octane booster, rocked the car about a bit to mix it, went for a drive and the pinging had stopped. I'm guessing it did just enough. I wouldn't (and don't) use it on fresh fuel, though. I think it's better thought of as 'fuel refresher'. :)
