It is currently Tue Jul 22, 2025 12:00 pm
 Post subject: 2 hole dash template
PostPosted: Thu Oct 14, 2010 1:39 pm
hello all, can anyone help with where i could find a 2 hole dash template? im in the process of trying to build a new dash for my clubman but the only templates i can find are pretty much 3 hole ones??
any help would be awesome!!!
cheers..
jess
PostPosted: Thu Oct 14, 2010 1:55 pm
by dash do you mean the vinyl backing on the firewall &bottom of the parcel shelf or a dash piece that holds two gauges? why not just drill only two holes if its to hold a gauge?
PostPosted: Thu Oct 14, 2010 2:02 pm
no, its the holes that house the speedo and fuel gauge etc.
instead of making the dash in 2 bits, i want to just have the one board with the 2 holes cut out, removing the cluster housing, i can do it the hard way and measure it up myself, but was hoping that someone has done it in the past.
PostPosted: Thu Oct 14, 2010 2:10 pm
this should help:
http://www.ausmini.com/forums/viewtopic.php?t=40484
PostPosted: Thu Oct 14, 2010 2:12 pm
thanks heaps!!
PostPosted: Thu Oct 14, 2010 2:36 pm
http://www.mediafire.com/?sharekey=d0cd ... f6e8ebb871
this has downloadable templates for dash and centre console and boot lining
This guy wrote some good notes too on how to do it.
http://www.theminiforum.co.uk/forums/in ... try1849337
PostPosted: Thu Oct 14, 2010 3:30 pm
Mods rock!
IwannaMini wrote:
http://www.mediafire.com/?sharekey=d0cd433132650c1375a4fc82078ae6c8e04e75f6e8ebb871
Hmmm.....dial 911 at the first sign of stroke. I'll have to remember that!
PostPosted: Thu Oct 14, 2010 4:03 pm
Not EVERY time you play with yourself...... :wink:
PostPosted: Fri Oct 15, 2010 7:41 am
thanks M...
should have just asked you in the first place!!!
cheers!
PostPosted: Fri Oct 15, 2010 7:58 am
I have all the tools and stuff if you want to bring a chunk of wood to make one at mine. Not sure what garage space you have or what tools you have.
This is how the one i did turned out....
PostPosted: Fri Oct 15, 2010 8:03 am
we started on the template last night, will hopefully start to "build" it on saturday, but if we get stuck i might head over, he is at kates place now, in the undercover car park, but so far so good, pretty sure we have all the tools, if not its just another excuse to head to bunnings which is about a 5 minute walk!! its awesome!
are those the pics of maisey????
PostPosted: Fri Oct 15, 2010 8:05 am
PS, she looks amazing!!!
PostPosted: Fri Oct 15, 2010 3:11 pm
Does a template for a centre bannicle speedo exists? (similar to that of a Cooper or K)
1966 Morris Mini Deluxe
.... 4 bicycles and 3 screaming kids.
PostPosted: Fri Oct 15, 2010 3:53 pm
Use the above for the outline and cut your hole in the centre
David L
