Super-mini wrote:
for a cheap road tyre i prefer the bridgestone sf226 to the falken, but if you dont drive too hard it wont matter too much.
i thought the a008's are bad in the wet due to their polka dot design.
I find A008s quite good in the wet, better than Bridgestones and far better than Falkens.
Rubber compound of the tyre is just as important for wet grip as tread pattern is. Go dig your fingernail into a Yoko, then try and do it to a Falken. Don't break your nail...
For an example, back in the 70s I used to run 13" Avons on the Fiat. Even when nearly bald they were far better in the wet than most other new tyres of the same size.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
