It is currently Mon Jul 21, 2025 4:56 pm
PostPosted: Wed Oct 27, 2010 10:40 am
Thought you may all like a look at a job that came in the other day.
It would be really great if we had a topic started that i (or others) could throw pictures in.
Anyhow here is an 1100cc crank and gearbox:
Andrew@Minisport, South Australia
Ph: 08-8177-1275
Skype: minisport.au
www.minisport.com.au
Minisport for all your mini parts
PostPosted: Wed Oct 27, 2010 1:01 pm
:shock: how does that even happen?!
PostPosted: Wed Oct 27, 2010 1:22 pm
ooohh SNAP!!
PostPosted: Wed Oct 27, 2010 1:29 pm
BIG BOOMBA!
was that a standard crank or a race engine or what?
PostPosted: Wed Oct 27, 2010 1:31 pm
Maybe leaving the overthrow nut off the clutch :roll:
David L
PostPosted: Wed Oct 27, 2010 1:54 pm
metal stress , out of balance forces, any number of things.
very unusual for the web to crack there, I would suspect that the crank has distorted or the block /mains are misaglined and the stress point is then acting on the web.
www.minisprintgt.com
PostPosted: Wed Oct 27, 2010 2:28 pm
This is what happened to a friend's car on the weekend at Winton.
We're pulling the motor apart on Saturday to find out what happened. The theory at the moment is a dropped valve.
Motor is a turbo 20valve 4AGE.
- Simon -
PostPosted: Wed Oct 27, 2010 2:34 pm
EWWWW that doesnt look good!
PostPosted: Wed Oct 27, 2010 2:44 pm
i love the 4age :cry:
PostPosted: Wed Oct 27, 2010 2:57 pm
Correction. The motor was a turbo 20valve 4AGE.
PostPosted: Wed Oct 27, 2010 3:06 pm
Now its a 19 valve 4AGE :lol:
PostPosted: Wed Oct 27, 2010 3:51 pm
Mods rock!
Perhaps not as spectacular as some above, but
1100 engine which had a big end let go.
Wreaked (shortlist);-
Crank
Block
Rod
Piston
Camshaft
Gearboxcase
About the only items that were salvagable was the head and rocker gear.
PostPosted: Wed Oct 27, 2010 3:55 pm
Some very tasty samples there :)
Rod Image
PostPosted: Wed Oct 27, 2010 6:06 pm
Slightly off the topic
Customer towed in a late model BMW a week ago because they drove it into flood water.
So we took the plugs out and started trying to turn it over, but it wouldn't budge, so we jacked it up and oil started running out :shock:
There is a hole big enough for my hand to fit through in the side of the block.
So remember peoples, if your not sure wether its low enough to drive through, don't try it! Especially if you own a nice expensive BMW.
PostPosted: Wed Oct 27, 2010 9:03 pm
I'm definitely keen to see the internals on the weekend.
It had been running 19psi for about a month or two. The little 1.6 made 240 rear wheel kW.
The boost got turned down to 10psi for the weekend at the track and that's when it went bang. Moral of the story?
- Simon -
Users browsing this forum: Bing [Bot], drmini in aust and 79 guests
