It is currently Sun Aug 17, 2025 11:57 am
Post new topic Reply to topic  [ 223 posts ]  Go to page Previous  1 ... 7, 8, 9, 10, 11, 12, 13 ... 15  Next
PostPosted: Sun Oct 24, 2010 7:59 am
I'm also still collecting parts.
Anyone got an A+ rod change box with all the bits to connect it to an 1100s engine??
M
PostPosted: Sun Oct 24, 2010 9:12 am
yeah
PostPosted: Wed Oct 27, 2010 11:27 am
Oh dear, worry, worry...
Hi All,
This is the dyno sheet from Specialty Components 7 port (on a proper engine dyno not converted drive on)
This is a CNC machined billet alloy head.
People we asking for dyno figures on some of these 7 ports.
Graham Russell
PostPosted: Wed Oct 27, 2010 12:27 pm
Milatsmadmini
nice one Grah-man!
PostPosted: Thu Oct 28, 2010 7:44 pm
[quote="GR"]Hi All,
Graham Russell
Hi Grahame. You're looking well!
Aren't you getting close to the same power from your 5 port big bores?
No decision is incorrect when made - but it does become apparent in retrospect...
PostPosted: Thu Oct 28, 2010 9:54 pm
He gets more these days.
Bling does not always = HP. 8)
PostPosted: Fri Oct 29, 2010 6:28 am
Hi Giddyup
I'm getting a lot more torque and HP than that from the 5 port motors.
Graham Russell
PostPosted: Wed Nov 03, 2010 10:29 pm
Some pics of the Pierce X Flow in a round nose. Gbox sitting in car with block on ntop and then head. Not assembled but gives you an idea of how it fits. Be better in a roundy with twin webers as the Dellorto brass screw cap on top just hits the bonnet when shut. Could squeeze some small filters on with out modifying the bonnet. The head shown is actually going in a clubby, but just thought I'd see if it fits!
What have other people done with thier 7 porters? Mine is ready to go on. Machine shop had to sink the valves 60thou to get the valve spring height and pressure correct with AEG 526 dbl vlv springs and 1.5 roller rockers. Not ideal but a compromise to be able to use a quality spring.
Now with 2 extra ports!
PostPosted: Thu Nov 04, 2010 8:45 am
Niiice!
S looks good too, I see wiring Loom.... check, Brake pipes.....check, should be on the road by Christmas!! :lol:
What are you going to do about the throttle linkage?
Cheers :wink:
Sir Alec! we are not worthy!
PostPosted: Thu Nov 04, 2010 8:49 am
Carbs are linked , Ill put a throttle wheel on the left hand carb and a bracket coming off a somewhere!
Head will go on the Van not the S. Can always get another one if we see some results.
All I want for Christmas is my S to run!
PostPosted: Thu Nov 04, 2010 3:56 pm
100ft/lbs (barely and not for very long) is rather disapointing...
Lillee - 1969 Morris Mini K
PostPosted: Thu Nov 04, 2010 6:51 pm
Those figures mean nothing to the owners of the heads that we have bought. We have different cylinder heads to the billet Specialty Components 7 port shown in GRs dyno sheet.
Can't wait for dyno results on our el cheapo 7 port heads.
on another matter......
I wonder what has the most potential for all out boom 5 or 7 port?
In standard or near standard tune what would be more drivable, 5 or 7 port? &
In standard or near standard tune what would give more get up and go?
With respect this is just something to talk about.
PS. thanks for the photos.
As you would all surely know we really can't compare Dyno results taken in the UK with dyno results here in Oz. There is only one way to use dyno results that would mean anything to anyone;
Same dyno,
Same engine (just change the heads, same comp ratio) as Vizard would to prove worth,
Same day,
Same weather,
Apples with apples
PostPosted: Fri Nov 05, 2010 10:25 pm
Cool video of an Austin America (1100) with 1380 and Pierce 7 Port X Flow.
http://www.youtube.com/user/edaniels98#p/u/1/9mbrJ0gw-lA
PostPosted: Sat Nov 06, 2010 7:05 am
Yah not really sure of the value of the comparison up top. Compare an 'as cast' 7 port to a 5 port that's been prepared by a guy with 4.7 bajillion hours experience doing just that :wink:
Sounds like there will be a few of these around, so will good to see what they can do once people have a bit of experience preparing them.
Going by the pics, I can't see one fitting in a roundie though - can you get a side on shot showing the clearance?
PostPosted: Sat Nov 06, 2010 8:29 am
Side On.
Users browsing this forum: No registered users and 268 guests
