It is currently Fri Jul 18, 2025 7:13 pm
Which is the easiest way to remove the radiator?
Cut the shroud 22%  22%  [ 7 ]
Jack up the engine 78%  78%  [ 25 ]
Total votes : 32
PostPosted: Wed Nov 10, 2010 3:01 pm
TheMiniMan wrote:
no different,,, it still has the same (similar) lower rad bracket that bolts to it,,,
you don`t take the engine mount bracket out
just undo the 2 "lower bolts" off the rad bracket --> the one that bolts in-between the rad cowl & the engine mount bracket
am i going to have to take a video of the job for everyone to see how easy it really is???
whack it up on you-pube :-)
:lol: :lol: :lol: :lol: I'll volunteer to come over and record it and we can time you :lol: :lol: :D :D :D hehe,
PostPosted: Wed Nov 10, 2010 3:03 pm
Make sure you do it on a really pretty car, so we can see you're not scratching it :P
PostPosted: Wed Nov 10, 2010 4:38 pm
Interesting read, and each to their own. I've never had any problem with the cut shroud, been doing them that way for over 15 years, never a problem. Dunno about them being weak?
Can have the radiator out in a similar time suggested, slaken off the fan belt, 2 shroud screws, 2 nuts/bolts on the thermo housing, bottom hose off the pump and top hose off the thermo housing or the radiator and it lifts out! Easy peasy. No mucking about with a jack, or the engine mount bolts, no crawling around on the ground.
But as I said, each to their own.
Steve
PostPosted: Wed Nov 10, 2010 6:36 pm
rad on a clubby should come straight out, plenty of room. turn the thing 45 degrees and work it upward over the fan.
on a roundy i remove the top shroud, unbolt the bottom one from the rad, and then slide the rad up and out.
pretty straight forward.
looking forward to Matts YouPube and hope it involves thongs and a BFH.
PostPosted: Wed Nov 10, 2010 6:58 pm
DUNNO WATTS HOLDING ON UR SHROUD ATM, BUT 2 SCREWS IT MUST BE HANGING THERE, ONE SCREW EITHER SIDE :roll: :roll: :shock: :shock: the km's i do, it would rattle loose in the first 500km's... :(
PostPosted: Wed Nov 10, 2010 7:44 pm
Get an A+ setup! 3 bolts , out!
Now with 2 extra ports!
PostPosted: Wed Nov 10, 2010 10:32 pm
Your (significant) ignorance is showing :shock: and that's no surprise to anyone :D
Steve
PostPosted: Wed Nov 10, 2010 10:38 pm
FLIP FRONT :) No radiator rash on the knuckles
www.minisprintgt.com
PostPosted: Wed Nov 10, 2010 10:43 pm
well im guessing ur only taking the bottom shroud off not the top while your at it to get it out of the way.. It has been 12 months since I've had a A series engine to work on (remember I do have the datty conversion..) and with the memory like mine, I wouldn't remember how many bolts there was..
PostPosted: Wed Nov 10, 2010 11:12 pm
Yep, 2 shroud screws are the 2 front lower ones. Top shroud and what is left of the bottom shroud (above the bottom outlet) stays on the radiator and all comes out with the radiator.
Even with the cut bottom shroud I've never had any problems with this mod, no rattles, nothing, in over 15 years and many km's in many different cars.
And as I said earlier, each to their own.
Steve
PostPosted: Wed Nov 10, 2010 11:45 pm
I must apologize,,, i`m sorry,,, i typed "3" upper rad bracket nuts (thermostat hsg) when i meant to type 2... sorry
& Lockie,,, if you want to talk about painful back ache--> I was born with Spina Bifida,,, look it up if you don`t know what it is
& no i havn`t bothered to even attempt to take the screws out of the rad cowl before removing any mini rad,,, never ever needed to... besides that i`ve watched & heard of too many people attempting such a silly method
& yes,,, i agree with justminis,,, each to their own,,,, absolutely for sure
anyone can do anything , anyway they want,
who am i & why should i bother trying to help
PostPosted: Thu Nov 11, 2010 9:57 am
You must have forgotten you told me when I was around at urs last.. :lol: one of the reasons why I mentioned my back and thought I mustive been going crasy to bend over a mini all these years... :lol: One of the reasons why I think you do well to bend over all this time.
PostPosted: Thu Nov 11, 2010 10:46 am
Isn't human nature wonderful - :roll: My way is better than your way - then there is Matts way - Sh!t the guy cut his teeth on an AF ring spanner and sucked grease from Mini nipples instead of mothers milk - what the rest of us (a few notable exceptions exclude) know about Minis collectively wouldn't fit under his little finger nail - yet people want to dispute is knowledge and experience - I'll take Matts advice any day without question
...end rant
David L
PostPosted: Thu Nov 11, 2010 11:06 am
I'll second this :wink:
PostPosted: Thu Nov 11, 2010 3:45 pm
I will jump on the bandwagon.
Users browsing this forum: No registered users and 112 guests
