It is currently Fri Aug 22, 2025 4:07 am
PostPosted: Thu Nov 11, 2010 3:04 pm
Milatsmadmini
So i finally pulled the block off the box, got me thinkin... ive got a couple 1100 cranks here, is it worth the $600 to redi-strip it, bore it and chuck some 100 thou 1100 pistons and rings in? it is the original block (number matched to car) which is what i am a little apprehensive about... but hell.... why not right? :?
PostPosted: Thu Nov 11, 2010 3:08 pm
Go for it! There ain't no replacement for displacement...
1/2 the 998s out there seem to have a 1098 crank these days.
It'll give you torque, something a Moke needs and a 998 lacks.
But I'd make it +.080", then you have 1 rebore still up your sleeve.
Or, if you want to save some $$$ use +.060" Hypatecs, they are cheap but good. That'll still give 1152cc.
PostPosted: Thu Nov 11, 2010 3:24 pm
Milatsmadmini
That was my thinking with the 1 rebore left...
Tell me more about these Hypatecs....?
PostPosted: Thu Nov 11, 2010 4:00 pm
Mods rock!
Understand the apprehension there. Get another block, they are (usually) cheap $20 to $50...
For a very cheap piston they do take a hiding. I've had some very good success with these. Certainly in almost any 998 or 1100 you'd be very happy with them. Just be sure you get supplied the correct (Hastings) Rings.
PostPosted: Thu Nov 11, 2010 6:12 pm
Milatsmadmini
cool, what sort of price are they and where is the best place to acquire said pistons and rings?
PostPosted: Thu Nov 11, 2010 6:33 pm
I'm usng Hypatecs in the Nb race mini.... so they can take a hiding...
Probably get at most of the usual suspects....
Lindsay has them at http://www.minis.com.au for $185...
PostPosted: Thu Nov 11, 2010 6:38 pm
Mods rock!
Try Lindsay
http://www.minis.com.au/minis/catalog/i ... Path=21_53
PostPosted: Thu Nov 11, 2010 9:25 pm
GT mowog wrote:
also try www.minisport.com.au
but add the postage and see who wins.. :lol:
PostPosted: Thu Nov 11, 2010 9:38 pm
I get a set of hypertec pistons and hasting chrome rings thru auto pro here for around $210 complete. Try your local auto pro place and see what they come up with. If no good I will see what I can do.
www.minisprintgt.com
PostPosted: Fri Nov 12, 2010 10:54 am
Milatsmadmini
alright.
Lindsay has them stocked and ready to go, 195 + 8.50 postage.
Im going to bore out my original block (fairly confident with this choice) and slot them in (at least ill still have 2 more rebores if need be)
Now, i have 2 1100 cranks... where can i take them to get looked over to determine which is the lesser of 2 evils?
And can someone make comment on Redi-strip? have you used them? what is the actual process they use etc...?
-matt
PostPosted: Fri Nov 12, 2010 10:58 am
Take both cranks up to Spiro, at
St George Crankshafts,
Bearing Rd, Seven Hills.
02 9674 1201
He regrinds all GR's cranks and knows what to look for..
re Redistrip, ask GR. They are good, but getting expensive...
PostPosted: Fri Nov 12, 2010 2:22 pm
Last time I used redi strip they charged about $200 from memory to strip the block (Chemical dips ect) they do a great job but yep, getting expensive!
Mini, its in my blood........
PostPosted: Fri Nov 12, 2010 2:35 pm
Mix up some [molasses + water] mix in a plastic bin, drop the block in there for 3 or 4 weeks. Every week, take it out and hose it, then stick it back in.:wink:
Note it works great on rust, but can't handle grease or oil. Degrease it first.
Last edited by drmini in aust on Fri Nov 12, 2010 2:36 pm, edited 1 time in total.
PostPosted: Fri Nov 12, 2010 2:36 pm
This space for rent
... and don't put any of the alloy bits in, unless you want to get rid of them :lol:
PostPosted: Sun Nov 14, 2010 10:49 am
I've tried this with smaller parts, but never a block. I've had better success with vinegar though - one part vinegar to about six parts water. Everything comes out looking shiny and new - the only way you can tell it was ever rusted is the holes where the rust used to be.
Having said this, I don't know how much it eats at the normal metal - I've used it on nuts and bolts and tuning pins for musical instruments without any hassle, but some of the surface must have been removed.
Users browsing this forum: No registered users and 260 guests
