It is currently Thu Aug 21, 2025 6:43 pm
 Post subject: Ign Light
PostPosted: Sun Nov 14, 2010 2:10 pm
Hmm...Marcia has a rebuilt Wiring Harnes and I'v got most of her sorted but unable to keep the heat down in the cooling system which everything is new except the radiator which was flushed,
The 1 thing has me questioning is the IGN light stays on when the engine is running. I have put all wire on as per the digram in 1 of the Haynes books but could this happen if I'm 1 terminal out on IGN Switch
PostPosted: Sun Nov 14, 2010 2:32 pm
More likely the alternator not charging, is it a known good one or a 2nd handy?
PostPosted: Sun Nov 14, 2010 2:35 pm
for gotten about why the IGN light stays on...its a unknown ALT so Ill pull it out and get it checked
Are the brushes readily available
PostPosted: Sun Nov 14, 2010 2:37 pm
Yep I got 2 sets for $30 at Tattersall Rd auto electric this year.
Could also be the V reg in the alt is playing up.
PostPosted: Sun Nov 14, 2010 3:24 pm
Get a multimeter Gaf, check if its charging, I had a cupla dry joints on the diodes on the back of my alternator, even after it was reco'd!
-Cam
IS NOW BACK ONLINE AFTER SOMETIME..... SORRY TO ALL, FOR NOT REPLYING TO PM'S!!
PostPosted: Sun Nov 14, 2010 3:35 pm
Battery out and back in Sue's Car. I'd prefer to change the brushed and Voltage regulator that way I know its done. I'm also going to take the Carb off again and give it a once over again as she does not want to rev properly any way..and chase down this heating problem (swap a few thermostats) & try again
PostPosted: Sun Nov 14, 2010 7:14 pm
sounds lean, could be the cause of your heat problems. hows your timing?
PostPosted: Sun Nov 14, 2010 7:39 pm
I was thinking that also...so spun it down a half turn which I thought would make it happy but didn't help. I used a EB Needle but have 2 TW & hard to see I think CL needle handy which would be closer than the TWs
Timing seams good but playing around with the Dizzy but idles good just don't rev at all
Users browsing this forum: justminis and 149 guests
