It is currently Thu Jul 31, 2025 9:28 am
PostPosted: Tue Nov 16, 2010 10:37 pm
Check your castor, measure from front wheel centre cap to the rear wheel centre cap, then do it on another mini.... If there close ur ok,if not I'd say you have the front hubs pulled too far forward.....creating a longer wheelbase.I can measure my car tomorrow arvo for you if u wish. I'm running 12x5superlites and fallen tyres with STD drums
Cam
IS NOW BACK ONLINE AFTER SOMETIME..... SORRY TO ALL, FOR NOT REPLYING TO PM'S!!
PostPosted: Tue Nov 16, 2010 10:46 pm
that would be good if u could. if they r to far forwad will i have to buy adjustable tie rod end bars ? to bring them back
PostPosted: Wed Nov 17, 2010 7:43 am
Get that measurement Cam! My tyres are rubbing on the guards too, worse on one side.
First thing I'm going to do is put a shim between the body and subframe to pull the guard forward a bit, then I'll wind the tie bars back if I can.
:D
PostPosted: Wed Nov 17, 2010 7:50 am
Where abouts is it actually rubbing?
PostPosted: Thu Nov 18, 2010 11:06 am
on the top when i bottom out and at the front of the guards
PostPosted: Thu Nov 18, 2010 11:29 am
Have you ever had your front apron panel replaced before???
PostPosted: Thu Nov 18, 2010 2:06 pm
not that i no of as far as i no it is the original one that came with the car y do u ask
PostPosted: Thu Nov 18, 2010 2:40 pm
I was having similar problems, rubbed even entering servo driveways or going around corners then realized the front bump stops had been removed when front shocks were fitted.
So check they are there and in good nick.
I fitted the standard ones that are bullet shaped. Glad I did because the Hydro collapsed shortly after putting new ones on but I was still able to drive (slowly) the car to the mechanic without it rubbing even with the car looking like this...
PostPosted: Thu Nov 18, 2010 7:46 pm
if that is sitting on the bump stops i cant do that cause the guard sits on my wheel and brakes my flair :(
PostPosted: Fri Nov 19, 2010 6:36 am
Yes, the full weight of the right side of the car is on the bump stops (hydro - all the fluid leaked out) and it was still drivable.
I have these on the front...
and these at the rear.
But if you are on dry suspension you may need to use something different.
If you have good bump stops fitted and they still rub then I guess in your case the 12 wheels inch plus tyres must have a slightly greater total diameter than 10's.
(I thought 12 inch wheels/tyres ended up the same diameter as 10's??)
PostPosted: Fri Nov 19, 2010 7:59 am
woodwormm wrote:
74snail wrote:
Also you only need 26psi front and 24psi rear
is this what everyone runs? i can never open that wheel/tyre page on here, my antivirus won' let me, it's full of trojans...
I run 38+, usually 40psi have a set of 10's and 12's handles very well ride is still plenty soft enough. Both on rubber cones.
67' Matic
73' S
PostPosted: Fri Nov 19, 2010 10:04 am
I run 30F/28R, A008s on 10x5 wheels. Car is hydro, handling and ride are good.
PostPosted: Fri Nov 19, 2010 8:12 pm
The normal setup was designed to be driven the the nearest service centre should all the fluid escape. BTDT - I think they recommended a maximum of 30 mph...
Cheers, ian
Users browsing this forum: Steam and 81 guests
