It is currently Fri Aug 08, 2025 8:14 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 191, 192, 193, 194, 195, 196, 197 ... 568  Next
PostPosted: Sat Nov 20, 2010 6:34 pm
Online
GT mowog wrote:
TheMiniMan wrote:
i did nothing on my mini today
Lazy SOB :lol: :lol:
Galston Gorge. :P
Did you guys notice the sand on all the hair pins?
Nope. We both run good 10" tyres (Yokohamas).What sand?? :lol:
PostPosted: Sat Nov 20, 2010 6:41 pm
Mods rock!
What sand?? :lol:
I went through on Wednesday and Thursday and someone / something had deposited quite a LOT of sand, but only on the hair pins....well, seems it's gone now, I have another few trips this week :)
PostPosted: Sat Nov 20, 2010 7:44 pm
what a place to put sand..had the Alternator looked at today.. Diode and possible Voltage reg but I did find a good Auto Lecky. Solderd the end of three Go Peddle cables and chose the best 1.
Found you can polish 2 pack paint 8)
PostPosted: Sat Nov 20, 2010 9:41 pm
turned key today :D it fired :shock: :D it only revs at about 2000 rpm must pull carb apart and check it out BUT it started, first try at pulsar dist and gemini starter must have been the good advise from the knowledgeable ones here thanks for helping so far
Darren
00 triton d/cab
55 chev(oversize moneybox)
1963 850 (roundie)
77 clubby
95 zxr 750 + toys!!
PostPosted: Sat Nov 20, 2010 9:57 pm
Fitted a new (old trusty) fuel pump - didn't work :evil:
1964 Nb Race Car - big bore short stroke & lots of revs - Sold
1969 Mk2 Cooper S - First Car
PostPosted: Sun Nov 21, 2010 1:39 pm
Fitted Battery, Fitted #7 Needle, Now Got Revs :wink: and have now found why she was Overheating..just have to wait for her to cool down now and workout why I do not have enough clutch, going to rebleed the slave
PostPosted: Sun Nov 21, 2010 5:47 pm
After 2 hard years of being thrashed the mokes 1275 needs a rebuild. she got less than 4 oil pressure at a warm temperature. She will probably get a bore out to 1293 and a qauiffe.
PostPosted: Thu Nov 25, 2010 1:54 pm
BUGGERBUGGERBUGGERBUGGER :evil: :evil: :evil: :evil: :evil: :evil:
We brought a double bed mattress up from Brissy last night on the roof of the Avalon and got home just as it started to rain- In my hurry to get it inside though the garage I wasn't looking where it was going and collected the Mini doors hanging from the rafters. The one with the new door skin came down and landed on its corner bending the lip back and putting a dent in the bottom of the door bin :cry:
David L
PostPosted: Thu Nov 25, 2010 2:21 pm
Got an exhaust bung welded on my exhaust pipe, for my Bosch wideband O2 sensor at Werribee Exhausts. Cost only $25! Bargain. :D
PostPosted: Thu Nov 25, 2010 2:36 pm
Online
Needed 1 brush for a Clubby wiper motor I'm fixing for an ausmini member (brush was broken).
I can still get new ones via the local auto leccy, it's $30 for the 3 aftermarket brushes and $15 for the freight, ta very much.:?
So I went down the road and bought 1/2 a s/h wiper motor for $10.:P
Hope there's 1 good brush in there...:wink:
[edit] Yes there's 2! 8)
Last edited by drmini in aust on Thu Nov 25, 2010 4:02 pm, edited 1 time in total.
PostPosted: Thu Nov 25, 2010 2:45 pm
bugger about the doors Wombat :(
I welded one on ages ago for a normal sensor, and went to put the wideband in it and the thread was OK, but the hole I'd drilled in the exhaust was too small - d'oh!
PostPosted: Thu Nov 25, 2010 2:56 pm
I asked the guy to fit it to my sensor; he was making the hole to fit an standard O2 sensor which had a smaller sensor head. Just as well I asked! :)
PostPosted: Fri Nov 26, 2010 7:37 pm
1. Replaced top radiator hose... see I do listen to you Mick!
2. Changed dashpot ATF oil to 20w50 to help with lean out on acceleration.
3. Connected up Tech Edge wideband and went for a short mapping run.
AFR now reads steady at idle since putting sensor in exhaust bung compared to tailpipe sniffer. Trouble is AFR is going wrong way upon acceleration. WTF?
Here is an extract of log:
Any ideas, what have I missed? Car drives OK.
Jim
PostPosted: Mon Nov 29, 2010 3:41 pm
My Wipers stopped working on the way to work this morning.
So, I pulled the cover off the wiper motor to find a lot of gunky/hard grease built up in there. I didn't want to remove the whole thing for a full rebuild, so i cleaned out as much of the gunk as I could. Then put some clean grease in there. Fixed
Gave them a short run to work the grease through it. Opened it up again, removed all the grease again because more gunk had been dislodged. Cleaned it up again, cleaned all the contacts. Re-greased, sealed it up and now it runs very well. A lot faster than before. :D :D :D :D
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Tue Nov 30, 2010 8:17 am
Removed door skin, started marking up hinge and latch holes on replacement skin I made recently. Challenging but rewarding!
the internet wrote:
Like Audrey Hepburn, almost everybody loves the Mini. The only people who didn't love the Mini were pathetic, empty people.
Users browsing this forum: drmini in aust and 84 guests
