It is currently Tue Aug 12, 2025 7:58 am
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
PostPosted: Fri Dec 24, 2010 10:35 am
GT mowog wrote:
Actually, they did. They came from the UK with tags riveted on and then removed here and stamped :wink:
Yes I know, 'they' refers to the Australian 'they' not the parent 'they'.
GT mowog wrote:
The ones cast here at Zetland, didn't have the rivet holes as they never had tags fitted, only engine numbers stamped on. All UK Blocks, as far as I am aware, only ever had tags riveted on, no stamping (how do they deal with theft etc???)
Potentially the UK system is a little bit more secure than ours. Anyone here can weld and grind or deck the number off, then stamp a new one on. The UK system would require you to get a replacement plate. The plates are stamped from behind with raised letters, which isn't something the average mug can do. I believe there is only one place in the UK who stamps replacement plates and he requires copies of your registration paperwork to do them.
My Traveller still has its original plate.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Fri Dec 24, 2010 2:09 pm
They didn't cast any blocks in Australia. Zetland didn't have a foundry. The blocks were cast in England and the engines were assembled in Australia.
So they all have the two holes on each end of the engine number. (despite what GT Mowog says)
You can tell an imported motor from a local motor. The local motor has two empty holes. The imported motor has two holes with cut off rivets.
PostPosted: Fri Dec 24, 2010 3:52 pm
I had one of them with the Australian stamp on it to.
PostPosted: Sat Dec 25, 2010 8:10 pm
Interesting, I thought some were cast here. I'd better re-read TME.
1955 BSA C11G
1969 Triumph TR6R
PostPosted: Sat Dec 25, 2010 8:16 pm
Mods rock!
There were. My former employer used to carry out maintenance to the foundry furnaces at Zetland BMC plant.
PostPosted: Sat Dec 25, 2010 8:17 pm
I believe some cranks and conrods were forged here (by ANI?), but no blocks cast.
PostPosted: Sat Dec 25, 2010 8:35 pm
Ok, I will bite, which ones were cast here?
Do you have a photo of one without the two holes?
What is the part number cast on the block?
And for an extra point, where were the P76 V8 blocks cast?
PostPosted: Sat Dec 25, 2010 9:58 pm
P76 6 cylinder blocks were cast here in Aus, they have mowog cast inside the outline of Australia on them,
P76 V8 Alloy blocks, prototype engines used castings from Birmal in the UK, production blocks were cast by Castalloy in Adelaide.
Have a Nice Day.
PostPosted: Sat Dec 25, 2010 10:54 pm
My Export moke has rivet holes but no aussie stamp. :cry:
Image Image
PostPosted: Sun Dec 26, 2010 3:59 pm
Most of the ones I have photos of don't have the stamp.
I bet when the stamp got blunt or broken it was not replaced. :lol:
PostPosted: Fri Feb 11, 2011 6:35 pm
Mods rock!
Here, for those who haven't seen one
See, no rivet holes. Cast at Zetland.
PostPosted: Fri Feb 11, 2011 6:41 pm
Show the cast number on the back of the block. :roll:
(btw, you can see one of the filled in holes when you blow up the photo, and what is that mark before the first digit? Looks like a re-stamp job. :roll:)
PostPosted: Fri Feb 11, 2011 7:51 pm
I bet there was a few of these no hole blocks in the hundreds of blocks, cranks, heads, gearboxes etc that were recently scrapped by the current owner of NMP. :cry:
Have a Nice Day.
PostPosted: Fri Feb 11, 2011 8:07 pm
I bought 2 brand new short motors from BMC back in the 60s. A 997 and a 1275 (M1100S).
Neither had the 2 rivet holes, or a stamped number, (or the map of Oz either) :lol:
I did the right thing and got NSW Police numbers issued and stamped on.
Users browsing this forum: goodie and 281 guests
