It is currently Sat Jul 19, 2025 12:09 pm
PostPosted: Mon Jan 03, 2011 9:33 pm
Reached the doors in my build project today. :D
Everything is on the edge of being seriously knackered. :shock:
Is there anywhere I can buy:
- external door handle
- lock assembly
- inner door handle
- lock
- window winding assembly
for both doors?
Regards,
Mike
"He who dies with the most toys wins."
PostPosted: Tue Jan 04, 2011 5:17 am
Mods rock!
- external door handle - NLA new, try ebay, they come up often.
- lock assembly - as in the barrel? These are available new, I think Mini's Plus has them.
If you mean the body lock assembly, these are also NLA, however, with a very small modification, it appears the late english ones are the same, mind you I haven't done this so I'm not 100% sure on it.
- inner door handle - NLA, however I am told late MGB were similar and only require minor modification to get them the same.
- lock - refer above.
- window winding assembly - John at Mini King has some new LH ones (although these are usually OK). RH is NLA new, but ask John. I referish mine, it's only the pressed steel 'bearing' on the shaft for the handle that wears (usually). I fit them with a small 'plumber block' style bearing, over the top, but it's cheap and easy.
PostPosted: Tue Jan 04, 2011 9:05 am
GT mowog wrote:
- inner door handle[/color] - NLA, however I am told late MGB were similar and only require minor modification to get them the same.
GT mowog is correct, The MG handles are basicaly the same, you just have to remove the spot welded plates and a rod from them, i have purchased some for one of my minis (i havnt got round to modifying them yet- but it's not as hard job).
See these as for what we mean:
http://cgi.ebay.com/ebaymotors/NOS-BMC- ... 5196be81fa
Or some second hand ones:
http://cgi.ebay.com/ebaymotors/MG-MGB-G ... 483df8070f
But i have trouble understanding how EVERYTHING could be wrecked? Maybe if it had been left in the weather and the door itself was wrecked aswell. Surely you wouldnt have to replace everything?
Brenton
PostPosted: Tue Jan 04, 2011 9:35 am
Thanks for the advice...
What do you mean by:
"I fit them with a small 'plumber block' style bearing, over the top, but it's cheap and easy."?
Any photos or instructions?
Regards,
Mike
PostPosted: Tue Jan 04, 2011 10:25 am
Mods rock!
This is the style plumber block (although here it is refered to as a flange bearing);
http://australia.rs-online.com/web/sear ... &R=3112724
But, you'll want them in 1/2" (from memory).
Sorry, no pics, there all behind the door cards now!
PostPosted: Tue Jan 04, 2011 5:01 pm
GT mowog wrote:
- lock assembly - If you mean the body lock assembly, these are also NLA, however, with a very small modification, it appears the late english ones are the same, mind you I haven't done this so I'm not 100% sure on it.
I'd be interested in any information that is available regarding this.....
Dicko.
PostPosted: Tue Jan 04, 2011 6:15 pm
Mods rock!
Dicko.
Maybe some kind soul, like Josh from Mini Imports could shed some light?
PostPosted: Tue Jan 04, 2011 9:27 pm
High heel ninja
I have most of what you are after in good 2nd hand parts.
Doogie
PostPosted: Wed Jan 05, 2011 8:35 pm
Mike,
I have two sets of winding mechanisms, but one pair have no springs attached. They are in excellent condition and have also been gold passivated. You can have the pair if you find the springs.
Come up this weekend if you want and we can rummage through my box of "door parts" and see what I have since I stripped TWO Minis.
-Alan
PostPosted: Thu Jan 06, 2011 4:02 am
Mods rock!
Mearcat wrote:
Mike,
I have a few springs I can send. Send me a PM.
PostPosted: Fri Jan 07, 2011 8:37 am
john at mini king sells reco locks keyed alike for $50
