stayed up last night and worked through the night on the van..
doing some maintenance for piece of mind for my SA trip coming back up soon, and to check the insides of the engine to see what they are like..
pulled the head off, and stripped it of valves, rockers etc.. ready for a good clean up from carbon and face lift of new paint, plus new valve stem seals and inspection of valves and seats.. not to meantion a look at the bores (were really good actually), & a better headgasket
Pulled the brake and clutch master cylinder off and pipe work ready for some new ones, and to allow the spray painting of the in desperate need of firewall face lift
Pulled the raditor out for a clean and inspection, old water pump off ready for a new high flow one, and old single timing chain off ready for the new double row one to go on once I get some sleep now..
(I WISH!!!,, soon off to work for the afternoon, hmm dont start till 4pm so maybe can get an hr of sleep in if im lucky..)
Old cast manifold off and ready for the new LCB extractors
much much bigger, and oh maybe a different head will go on with port and polish work thats been done to it, and bigger valves instead of this one it came off, not sure yet...
Front bumper also came off ready to fit the better looking one I have now...
old steering rack is out ready for the new reco'd one to go in... front cones out, ready for the hi lows to go in instead... ummm what else did i do last night.... pulled out the wet carpet inside and pulled the seats out, to let the thing dry inside as it was getting mouldy rusting my floors... Will just be putting down matts this time around, not full carpet... that way it can air...
hmmmm oh and pulled the pooped clutch slave off, ready for the new one and its braided hose... plus tried to get the front brake hoses off ready for them as well,, however can't crack the thread yet.. rusted in...
Then off to the rear of the car for hi lows, brake hose replacements, brake shoes, oh and the brake shoes at the front will also be replaced.. then I'll start from sratch and begin to put all the new stuff in once I get the old crap out
arhhh i think that was one productive night myself
