It is currently Fri Aug 08, 2025 6:31 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 202, 203, 204, 205, 206, 207, 208 ... 568  Next
PostPosted: Fri Jan 07, 2011 3:36 pm
Mods rock!
Everybody here has em on order from UK but they are not forthcoming... and it's been a while.
Maybe RHP/NSK don't care, they're not a volume item now.
I've still got 1 left.... :wink:
I think a big part of the problem is the cheap (and nasty) complete racks that are flooding the market. Nobody wants to overhaul anymore.
PostPosted: Fri Jan 07, 2011 5:12 pm
Painting (primer) and installing the side windows:
I tinted the windows last night, which worked okay. A couple of small hickies but they look fine from the outside. Refitting the trim is a b!tch, nasty little rivets and self tappers mainly.
The Estate is going to be yellow again, but I painted the trim separately. I'll fill the inevitable gap with seam sealer as soon as I work out a way of 'piping' it into the gap. I have to paint the car in stages as my garage isn't big enough to do it in one but I'm quite happy with the results so far.
PostPosted: Sat Jan 08, 2011 9:14 am
I washed it the other day. After months of it being filthy from chasing poeee through puddles...
puddles are fun :twisted:
78 Leyland Mini - Prince
PostPosted: Sun Jan 09, 2011 7:55 am
Some pics of the trailing arm refurbishment...
[img][img]http://i17.photobucket.com/albums/b99/CPOCSM/DSC00886.jpg[/img][/img]
RH arm removed(along with 30++years of soil laden grease!)
[img][img]http://i17.photobucket.com/albums/b99/CPOCSM/DSC00880.jpg[/img][/img]
LH still in car - nowhere near as bad as the RH one.
[img][img]http://i17.photobucket.com/albums/b99/CPOCSM/DSC00879.jpg[/img][/img]
RH out and on the floor
[img][img]http://i17.photobucket.com/albums/b99/CPOCSM/DSC00884.jpg[/img][/img]
LH out on the floor
[img][img]http://i17.photobucket.com/albums/b99/CPOCSM/DSC00882.jpg[/img][/img]
RH blasted with pressure cleaner and repainted in satin brake black - noice!
[img][img]http://i17.photobucket.com/albums/b99/CPOCSM/DSC00881.jpg[/img][/img]
The bumfight that is the wiring - might just put it all back and splice...grrr
[img][img]http://i17.photobucket.com/albums/b99/CPOCSM/DSC00877.jpg[/img][/img]
While I was waiting for paint to dry, hung a pegboard and sorted the tools out...wheee!!
More to come
Hooroo
Skins
Rob Forsyth
Miniot!!
PostPosted: Sun Jan 09, 2011 6:33 pm
Today I:
Fixed things that I fixed previously.
    After putting in a new Smiths tachometer, I found out a couple days later that my dash lights and tailights turned off when the headlights were turned on. Solution: put the wires on the back of the light switch, (where I tapped in for the dash light for the tacho), in the correct position! :oops:
    Car was running rough at idle, it was still idling around right revs, but when I checked the AFR, (I'm running Megasquirt with a wideband O2 sensor), it was showing readings between 16-19:1 at idle. Yet the ignition was having no major problems igniting it. Solution: put back the MAP sensor tube to the manifold! :oops:
Moral: Check your work, then re-check it. :lol:
 Post subject: Continued Stripping
PostPosted: Sun Jan 09, 2011 7:32 pm
Continued stripping the morris, finding all the rust
Will be a while at this stage, as I need to replace the floorpans, boot floor & front panel..
'67 Deluxe (WIP)
- down to the shell..
PostPosted: Sun Jan 09, 2011 7:51 pm
Watched her 1978 era paint boil and flake off, bloody hot days.
MOVE OUT KIDS , my Mini wants her garage space back :evil:
Master of the Moggie Army & Founder of Awesomestock2010
PostPosted: Sun Jan 09, 2011 8:16 pm
Put the body onto its new trolley and then assembled all the parts and body kit in preparation for the paint shop.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Mon Jan 10, 2011 2:48 pm
Making way for Clubman Window Van in garage, pulled the Buick V6 out of the MGB...getting it ready to sell off.
PostPosted: Mon Jan 10, 2011 4:28 pm
(Yesterday) Rummaged around under the house and found a nice piece of wood I can rip up and make two of the wooden blocks to stick under the front subframe to use as jack point. If I end up with two finished blocks I'll have one to sell :wink:
David L
PostPosted: Mon Jan 10, 2011 11:57 pm
Did a bit of degreasing of the new engine, most grime looks to have been caused by pot joint grease and not actual oil. My left wrist is in a splint at the moment so I don't have alot of movement which means I can't get to work re-painting and fitting it all back in Hetty.. Soon though. :wink:
PostPosted: Tue Jan 11, 2011 5:15 am
got rammed in the back on the way home from the vmci committee meeting
bent the rear doors
'was not concentrating'
she said 'was lookind down not up'
texting maybe???
find out tonight how much?
PostPosted: Tue Jan 11, 2011 6:30 am
bent the rear doors
texting maybe???
Sorry to hear that, why do people still not understand that mobile phones are dangerous when mixed with driving.
ANY SEA ANY TIME
PostPosted: Tue Jan 11, 2011 6:44 am
^^^ What a PITA. Hope it's not too bad. Is cellphone use in Aus not illegal? They made it illegal here about 9 months ago.
PostPosted: Tue Jan 11, 2011 7:22 am
Angusdog wrote:
^^^ What a PITA. Hope it's not too bad. Is cellphone use in Aus not illegal? They made it illegal hear about 9 months ago.
It is in Victoria, not sure about the other states. I personally believe it is hard to police since when we go home and switch on the TV, all we see is Americans talking away on their cells in their cars whilst driving ! :x End of rant. 8)
Users browsing this forum: drmini in aust and 99 guests
