It is currently Fri Aug 08, 2025 7:34 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 203, 204, 205, 206, 207, 208, 209 ... 568  Next
PostPosted: Tue Jan 11, 2011 8:41 pm
Fitted the crankshaft into the block. And I put the thrust bearings in the correct way around. :)
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Tue Jan 11, 2011 10:10 pm
NAV-MAN
Are you sure???? :wink:
PostPosted: Wed Jan 12, 2011 12:53 am
Washed the months and months of built up dust off Hetty. Hope to start cleaning up the engine this weekend.
PostPosted: Wed Jan 12, 2011 5:34 pm
Spent about half the day cleaning all the oil and grease from the engine, then gave it a lick of paint.
ANY SEA ANY TIME
PostPosted: Wed Jan 12, 2011 6:10 pm
Just drove it! :lol:
PostPosted: Wed Jan 12, 2011 6:19 pm
yesterday went up to mini maxxs to get my floor and front guards and my new doors.
Thanks heaps mini maxx
PostPosted: Wed Jan 12, 2011 11:02 pm
installed new doors seals and then proceeded to get all confused on how to remove the door window to fix the winding mechanism and install new felt seals. any ideas?
PostPosted: Thu Jan 13, 2011 7:56 am
installed reco door locks from mini king,so nice to be able to lock & unlock the car
PostPosted: Thu Jan 13, 2011 3:40 pm
Attempted to get 4myego's Mk2 Cooper S running properly. The old twin HS4s seem to have a serious problem- so in a day or so it's getting Lockie's Dellorto DHLA45 and ported Redline 3005 manifold fitted. A proper carburettor, Made in Italia. :mrgreen:
{edit}
Fitted it today, then turned the key and it roared into life.
I'd guessed at the idle screw setting, but it sat there purring like a kitten at 800rpm.
Jetting is same as mine at present, we'll play with jets next. :wink:
Last edited by drmini in aust on Fri Jan 14, 2011 8:39 pm, edited 1 time in total.
PostPosted: Thu Jan 13, 2011 3:53 pm
cried a little :(
See: http://ausmini.com/forums/viewtopic.php?t=68214
PostPosted: Thu Jan 13, 2011 5:20 pm
Today I replaced the rear spacer drums back to original standard new ones so as to get the 6" Mambas back under the flares. Painted the drums silver so you can now see the wheels more clearly. 8)
Tomorrow I will wire up the twin relays for the H4 headlights and driving lights.
Dave K.
PostPosted: Thu Jan 13, 2011 7:42 pm
Cut and bent some tube for new front brake lines.
ANY SEA ANY TIME
PostPosted: Thu Jan 13, 2011 9:07 pm
pulled apart 1098 motor to replace lots of gaskets and seals.. All looking good so far. Not taking any painkillers because I didn't want my brain all fuzzy, so I now have a very sore wrist. Taken drugs now so in about 30 mins I'll probably forget that I own a Mini or two. :)
PostPosted: Thu Jan 13, 2011 9:42 pm
Got my 1360 7 port running - stoked!
Easy job when fuel actually comes out the carby like its supposed to!
Now with 2 extra ports!
PostPosted: Mon Jan 17, 2011 9:48 am
More body work. Stripped paint from most the front of the car, then started on touching up the rear doors. The lower 2 inches of one door need replaced, so that will be a test of my fabrication skills...
Also bought a new pair of seats from a 2005 Fiesta for NZ$80. Almost too tall for the Mini but will work.
Users browsing this forum: AWOODY and 81 guests
