It is currently Sun Aug 17, 2025 2:57 am
Post new topic Reply to topic  [ 223 posts ]  Go to page Previous  1 ... 9, 10, 11, 12, 13, 14, 15  Next
PostPosted: Wed Jan 19, 2011 8:16 am
I had a quick squirt in this beast last night, man it's got potential! :shock:
Probably needs more advance early in the curve, some cooler plugs (it gassed up on me at a junction).
Super, I sent you a PM about choke sizes, what are they?
Dr or anyone, what do you think for a 1360 with 2 x 40 Dellorto's ?
It's sure got some grunt! :shock: :lol: :shock: :P
Sir Alec! we are not worthy!
PostPosted: Wed Jan 19, 2011 9:07 am
I'm also interested in carb settings for my pair of DHLA 40s
Doc Martin (the ebay supplier of the heads from the states) gave the base settings for 40mm DCOEs as:
> Chokes 30
> Main Jets 120
> Air correctors 180
> Emulsion Tubes F11
> Idle Jets. 50 F9
> Happy Motoring! Doc Martin
PostPosted: Wed Jan 19, 2011 9:58 am
Hi Graham What chokes are in the 40's?
PostPosted: Wed Jan 19, 2011 11:53 am
32mm chokes in the dellortos. Not sure what jetting Dyno dude put in. Will pull them out and have a look. Cheers.
Now with 2 extra ports!
PostPosted: Wed Jan 19, 2011 12:41 pm
Congrats SuperCooper,
Sounds like we are onto a winner. :)
PostPosted: Wed Jan 19, 2011 3:40 pm
Sorry should have also asked, what jets and air correctors are in there now?
Wild guess would like something like 125 or 130's mains?
PostPosted: Wed Jan 19, 2011 5:46 pm
Ok spent Arvo sorting a few things. Fixed rear ex bracket and noticed lcb to pipe u bolt was lose. Now fixed.
Changed coils, previous one had a dodgy post.
Spaced ht leads with proper spacers.
Very happy now the 90.4 hp works from idle right through!
Jetting - mains 158, pump jets 40.
This head has been ported , polished and flow benched.
Can't wait to get a decent ex and see what happens! A brownrigg would be nice if they were available.
Cheers!
PostPosted: Wed Jan 19, 2011 7:31 pm
DHLA 40 Carb settings on my car are as follows:
32mm choke
Idle jet - 40
Main - 158
Emulsion - No 10
Air correcter - ? can't read the numbers.
Pump Jet - 35
Can someone convert that to a weber equivelant?
PostPosted: Wed Jan 19, 2011 10:23 pm
Awesome! was the coild the problem then? :?:
Can I have another go!! :lol: :lol:
PostPosted: Sun Feb 20, 2011 2:48 pm
Are these heads - stage 3 package, ready to bolt on or do they require a lot of mucking/modifying to work. Has anyone got one running porperly yet? Am interested in buying one but would like to know if there worth it? How'd you go with yours TK?
PostPosted: Sun Feb 20, 2011 3:23 pm
32mm choke
Idle jet - 40
Main - 158
Emulsion - No 10
Pump Jet - 35
Jet sizes would be near the same. On both carbs they are expressed in mm diameter (eg a 158 main is 1.58mm).
Emulsion tubes Dello/Weber I dunno, as they don't cross correlate. It's a matter of finding what works. Your 10s are probably the Alfa ones (fine with twins, don't work on a single Dello on a Mini- they need a 5, 6 or 7)
PostPosted: Sun Feb 20, 2011 6:18 pm
My project is on hold at the moment with a rebuild of Slidey's gearbox, slack 2nd gear syncro.
Soon though you'll probably get the results of a out of the box bolt on to a stockish 1275.
These things are great value for money. Especially with the Oz dollar being so good.
PostPosted: Mon May 09, 2011 7:35 pm
So has anyone got one of these running in brisbane yet? Ty, Dave? My old man is on the verge of buying one and wouldn't mind some input.
PostPosted: Mon May 09, 2011 7:41 pm
excellent! that's what i am looking at doing
PostPosted: Mon May 09, 2011 7:48 pm
Have you read this thread? I have had mine running for quite some time now.
However I am in NSW, not Brisbane like you asked!
