It is currently Fri Jul 18, 2025 4:55 pm
PostPosted: Sat Oct 16, 2010 12:16 pm
I need to make a bracket for my car that allows me to fit a late model fuel tank.
The early tanks had the strap go over the tank and mounted to the floor, but the later tanks had the strap go around the tank and anchor to a bracket welded into the floor the early cars don't have.
I need to make a conversion bracket. It won't be welded to the floor so instead it'll be a bolt in job. I'll use the existing captive nut in the floor and the rear subframe mounting bolt to hold the bracket down, and and a vertical component can have the hole for the strap to screw into.
What would be very useful to me is if anyone can get me the location of where the hole in the bracket needs to be relative to the subframe bolt.
In the above image, red is the height of the bolt to the floor, blue is the offset of the tank bolt to the subframe bolt, green is te offset of the bracket face to the subframe bolt and the yellow cross is roughly where the subframe bolt would be.
Any help at all would be very much appreciated.
Thanks.
:D
PostPosted: Sat Oct 16, 2010 12:25 pm
Not 1275LS. :cry:
PostPosted: Sat Oct 16, 2010 12:30 pm
Supercharged
the standard tank strap still works with the long range tank, have you tried that?
PostPosted: Sat Oct 16, 2010 12:32 pm
That is how the 1275LS tank was fitted.
PostPosted: Sat Oct 16, 2010 12:37 pm
I did try that but it seemed a bit unstable, and that was with an empty tank.
I figured that's why they changed it.
Maybe I'll revisit that.
:D
PostPosted: Sat Oct 16, 2010 2:03 pm
Don't need the numbers anymore, I made a bracket up already that does the job well.
Still using the rover bracket, I just made a small angle piece to fit in the bottom between it and the morris mount.
Its in, and rock solid. :D
PostPosted: Wed Jan 19, 2011 12:05 pm
I'm fitting a late rover MPI tank as well to my '68. What does your bracket look like? Is it just a right angle bracket that bolts to the original captive nut that the early tank strap fixed too? Sorry, but I'm visual... could I be a pain and have a picture? :oops:
PostPosted: Wed Jan 19, 2011 12:14 pm
I'll get a photo of it if I remember some time but as you said, just a right angled bracket mounting to the captive nut.
I used the rover tank, strap, the 3 inch bolt and the clip on 'captive' nut. The bracket is only little, less than 2 x 2 x 2 inches.
It's straight forward to set up, the only trick is that there is a hole in the bottom of the fuel tank that looks like a mounting hole: it isn't used at all, the bolt at the end of the tank strap goes under it.
:D
Want photos of where the fuel hoses go through the floor whilst I'm in there?
PostPosted: Wed Jan 19, 2011 12:26 pm
:D
Wow that was fast service! :lol:
I was wondering what the hole was for... More photos the better, I have to drill one more larger hole and a smaller one for the over flow/vent. I'm putting the fuel regulator in the boot and the rover fuel filter on the subframe underneath. See http://www.ausmini.com/forums/viewtopic.php?t=67644&start=32
Thanks in advance. :D
PostPosted: Wed Jan 19, 2011 1:46 pm
If it helps, the rover fuel filter is has the same fittings as Honda filters (possibly because it's a standard thing I'm not sure) but useful to know.
PostPosted: Wed Jan 19, 2011 2:15 pm
Handy to know. I've got a brand new filter and a S/H Rover filter bracket. It mounts to the subframe via two small bolts. Here is an image I gleamed from the net:
Unfortunately even though the two holes are there, the filter bracket fouls on the brake pipe that runs near there. I guess the Rover pipe lines are routed differently. Never mind, I'll just move the filter back to the rear of the car by one hole and drill a new hole. :roll:
PostPosted: Wed Jan 19, 2011 3:51 pm
I have the rover filter and not fouling brake lines, I'll measure how far back it sits.
PostPosted: Wed Jan 19, 2011 4:35 pm
Did you have to drill an extra hole? Or did you just fit it to the two holes already there?
PostPosted: Wed Jan 19, 2011 9:13 pm
Here's some photos.
Sorry they're useless, but that's what happens when everything is the same colour.
PostPosted: Wed Jan 19, 2011 10:35 pm
Harley wrote:
Here's some photos.
Thanks for that. I can now see the bracket quite clearly. What are those connectors that you are using, are they bulkhead connectors?
Users browsing this forum: Bing [Bot] and 104 guests
