It is currently Fri Aug 01, 2025 11:38 pm
PostPosted: Wed Jan 26, 2011 5:56 pm
so just put a new gasket it on today & it's seeping slowly a bit of coolant out of one bolt.
what have I dont wrong? not enough gasket goo? i tried to do it nice & neat?
normally i just smear it on thick as hell.
anyways what's should i do.
PostPosted: Wed Jan 26, 2011 6:13 pm
A bit of poop stuck on the gasket face?
Or on the bolt?
Or maybe not 100% flat next to the bolt/stud?
There's a path from the thermostat to the stud, most likely only cured by getting it off and checking it all again...
Jacob
PostPosted: Wed Jan 26, 2011 7:09 pm
just took it back off i cracked the gasket! bah..
what gasket is better the cork ones or the paper ones?
PostPosted: Wed Jan 26, 2011 7:31 pm
Gasket in a tube mate, Silastic
Master of the Moggie Army & Founder of Awesomestock2010
PostPosted: Wed Jan 26, 2011 7:38 pm
don't have any handy, but you would rate that over the normal gasket?
PostPosted: Wed Jan 26, 2011 7:41 pm
I prefer the paper gasket, the cork ones squeeze out.
I smear Loctite 515 on them. Better on an engine than using that silastic crap... it belongs on roof gutters. :P
This space for rent
I just use a roll of gasket paper and cut out the right shape, then use a little Permatex red silicone. I find the surfaces are all pitted after all this time, and the gaskets alone just won't seal.
Sometimes takes a couple of goes to get a seal, but I won't put up with a coolant leak there :lol:
PostPosted: Wed Jan 26, 2011 7:48 pm
yeh i had a corck one it split and over heated my car a while ago.
ill grab a paper one tomorrow & smear the crap out of it!!
:D
PostPosted: Wed Jan 26, 2011 7:49 pm
Making your own is the way to go if you don't have any handy. And if you don't have any gasket paper around, you can always use your cereal box and just use a light smear or whatever goo you have to help with any pitting etc on the surfaces.
PostPosted: Wed Jan 26, 2011 7:51 pm
yeh none handy matt..
not to worry ill get one tomorrow morning and some paper for future reference.
PostPosted: Wed Jan 26, 2011 8:46 pm
Those gaskets I am always happy to buy half a dozen when I just need one. The problems always strike on a public holiday...
You can get some really nice thick paper ones as well. I like these ones for some reason, they seem less inclined to problems as the super dooper thin paper types which come with the thermostat covers included in the bag.
PostPosted: Wed Jan 26, 2011 9:32 pm
MinisPlus
When I've encountered this problem, the easiest fix is to put an 'o' ring on the stud between the housing and the flat washer.
2 mins to fix and no more leaks!
How can it be rusty when it's covered in so much oil?
PostPosted: Wed Jan 26, 2011 9:40 pm
i will have to get the thick ones mick.
i think ill buy a new one tomorrow thin & get some nice thick gasket paper & cut my own out.
PostPosted: Wed Jan 26, 2011 10:09 pm
I like the o-ring idea. Some of these old heads will really give you the irrits. There's bugger all gap between the thermostat land and the stud.
PostPosted: Thu Jan 27, 2011 5:32 pm
I use Permatex Number 3 on the gasket and I coat it on the studs as well to prevent leaks and to prevent corrosion.
It will still come apart in 10 or 20 years without breaking the housing.
