It is currently Sat Aug 09, 2025 3:40 pm
PostPosted: Fri Jan 28, 2011 10:58 pm
HI GRAHAM
so have you worked out part down throttle problem?
PostPosted: Sat Jan 29, 2011 6:44 am
Mods rock!
aaron wrote:
It is a nice red isn't it.
Yes, I would have to agree on that.
PostPosted: Sat Jan 29, 2011 8:49 am
I personally like Green motor's (and there's a debate there, which one's right?)
But for a red, it's nice.
PostPosted: Sat Jan 29, 2011 8:53 am
Mods rock!
Most 'straight' colours are nice I recon as long as it it done in a 'detailed' way ie, not fully assembled and then run over with a spray can. A few small different colours, like gearbox, transfer housing, rocker cover, thermostat housing etc set it off.
PostPosted: Sat Jan 29, 2011 12:00 pm
Have you found green motors to be quicker?
PostPosted: Sat Jan 29, 2011 12:12 pm
I like black ones; they are no faster, but you can't see them coming! :P
PostPosted: Sat Jan 29, 2011 12:28 pm
what about a GAFMO polished one? With a nice coat of clear over the top? :D
mooo, I'm a pig!
PostPosted: Sat Jan 29, 2011 12:29 pm
Black is great on a road/race motor, you don't notice the oil leaks
PostPosted: Sat Jan 29, 2011 12:34 pm
Thanks GR, its really great to see dyno results for a supercharged A series. I run the same model supercharger on my 1330 mini. Suprised to see the lack of boost in the lower rpm. My mini pulls smooth and sweet (hard :twisted: ) right from idle, even with the tall diff and big wheels (13x7''). By 2000rpm ive reached 80% of full boost. When i asked Hans (with an "s" :) ) why there was such an apparent difference to my engine he immediatly said "compression, cam and exhaust." He went into detail that i wont go into here. He was rather horrified to see the Supercharger running without any form of airfilter also. Regarding the s/c running out of puff- Hans showed me the airflow of this model, it has 185hp potential. He said the BMW s/c is a good quality unit but is still based on the cheaper, less efficient , Eaton "roots' style.
PostPosted: Sat Jan 29, 2011 12:38 pm
Mods rock!
Micowen, what's a good clear to use? The stuff I've been getting of late ain't what it used to be.
PostPosted: Sat Jan 29, 2011 1:46 pm
Hi Graham, is that an mpi pulley with damper integral? I need one of those belt tensioners too, can you advise where to get one please.
Jason
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
PostPosted: Sat Jan 29, 2011 3:46 pm
I'm sure I can get my hands on some 2K heat resistant clear!
Maybe some of the special clear that I'm gonna be using on my deluxe could work, I'll pop a few questions and see how we could get around its difficult adhesion problem! :wink:
Leave it with me boss! :D
mooo, I'm a pig!
PostPosted: Sat Jan 29, 2011 4:09 pm
Jason
the supercharger kit is set up by Link auto in Melbourne, they'll advise you on those parts.
