It is currently Tue Jul 29, 2025 1:20 am
Post new topic Reply to topic  [ 153 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9 ... 11  Next
PostPosted: Wed Feb 02, 2011 9:40 pm
cool, Thanks.
I might ask the Wurth rep when he comes in to work next time. They are sure to sell some sort of good stuff for it. :D
Dusk Blue
1964 850
PostPosted: Fri Feb 04, 2011 7:44 pm
Found it... Chemsearch Yield
PostPosted: Fri Feb 04, 2011 8:09 pm
modded 1098 engines I have two
Wife / Mine (just built)
1098 / 998 block
+60 / +40 Pistons
Standard / Balance and straightened Rods
RE13 / RE83 Cam
10:1 / 9.5:1 Compression
+60thou / 20 Head Flat maybe +20thou unsure - 202 Head Skimmed
1098 Cranks for both & are balanced first then with (lightened) fly wheel then back plate and clutch
HIF44 / HS4 Carb
3.44 / 3.6 Diff
Both Running 10" Wheels
Wifes Motor has made 45.4 HP with out a proper tune up but with the Diff its better on the 110kph where mine will be better off at the lights
do what you would do to a 1275 and you will have a all day motor & fun on the week ends. And You I intend to have fun in mine also
PostPosted: Fri Feb 04, 2011 9:53 pm
cool thanks guys. :D
Where did you buy that stuff from morris????
i have some Wurth synthetic penetrating oil aerosol that a guy from work says is pretty good. i'll give it a go and see if it works.
Dusk Blue
1964 850
PostPosted: Sat Feb 05, 2011 6:51 pm
well it worked a treat. got it all apart and cleaned up. Now i'm putting it back together and i am wondering if i should be putting grease on the throwout plunger thing. should i ? if so what sort?
Dusk Blue
1964 850
PostPosted: Sat Feb 05, 2011 7:09 pm
That stuff looks awsome
PostPosted: Sat Feb 05, 2011 7:13 pm
I didn't buy it, the plant mechanic stole it from another plant mechanic!
So how did the Wurth stuff go?
PostPosted: Sat Feb 05, 2011 7:15 pm
I use Castrol HMP wheel bearing grease, it stands the engine heat and doesn't run out.
PostPosted: Sat Feb 05, 2011 8:42 pm
Yea it seemed to work well. I don't know that it is actually designed for that purpose, but they told me that it'll do the trick, and it did. :D
This is the stuff anyways..... http://www.wurth.com.au/catalogueview.a ... 4_0526.pdf
Cool, thanks for that. Actually looking at the pdf for this wurth stuff, i wonder if it'd do the trick :? ???? or would the grease need to be a bit thicker???
Dusk Blue
1964 850
PostPosted: Sat Feb 05, 2011 8:50 pm
I'd try it and see, most Wurth stuff is good (but pricey).
PostPosted: Sun Feb 13, 2011 8:48 am
whats the difference between this, my old 72 clubbies 1098 engine
And this, the 1098 engine in my current car
Dusk Blue
1964 850
PostPosted: Sun Feb 13, 2011 5:48 pm
The old one, the bores are worn?? :lol:
A 1098 is a 1098, until you modify it.
:P
PostPosted: Sun Feb 13, 2011 7:48 pm
:lol:
Sorry it wasn't meant to be a trick question...
I was just wondering why the bit at the back is different. I circled the bit i mean.
Dusk Blue
1964 850
PostPosted: Sun Feb 13, 2011 8:01 pm
I dont know why they are different, but that is a bolt on part that you can take off and swap whatever.
I would say one is a mini K motor 10Y and the other a clubman block 1001(something like that)
So an age gap that is my guess. :?
PostPosted: Sun Feb 13, 2011 8:07 pm
One is a very early Morris 1100 motor and the other is from a later motor with a PCV valve. (1100S, Cooper S, etc)
