It is currently Sun Jul 27, 2025 3:38 pm
PostPosted: Mon Feb 14, 2011 8:55 pm
Online
SuperCooper wrote:
Great , so many useable parts in em! And they should all be in good cond too. Will see when i get time to pull one down - dam Mini 50! Sooo many things to do........
The pistons must have a considerable dish in them if the high compression motor was 8.6 to 1. What was the Low comp ? 5 to 1!
There was no low compression option.
8.8:1? I think (I've never heard of 8.6) was the low compression 1275 motor. Dunno why they stamped H on these blocks. (Cooper S was the high one back then)
1100S goes lots better with a set of 9.75s in there. :wink:
PostPosted: Mon Feb 14, 2011 9:04 pm
This seems and oddity, all the literature (& I mean ALL) has the 1100S at 8.6:1, 63hp & 71lb/ft.
All the pommy non S motors seemed to get 8.8:1, maybe the Oz ones got local pistons or something?
Jacob
PostPosted: Mon Feb 14, 2011 9:24 pm
Radiator wil fit into a clubman.
A mate used to run one his GT and it stayed cool throughout summer nomatter how he drove. He said the bottom mount was awesome because it was just one bolt that was easy to get to and the whole radiator came right out
PostPosted: Mon Feb 14, 2011 9:51 pm
In a clubby they will fit, and work well. but not in anything else.
done it many times!
Why is it the things that make me tick, are also the things that make me go boom?
PostPosted: Tue Feb 15, 2011 3:22 pm
Jacob
You have to realise that each country has different petrol so they may have needed to play with the compression to suit what is available.
The factory made the motors to suit what the market wanted, the Morris 1100 had 50 BHP and they wanted to give it a boost with the 1100S.
So 63 BHP was a big increase over what was the normal power for a car that size.
They probably didn't need to run the compression any higher to sell all the cars that they could make at the time.
PostPosted: Tue Feb 15, 2011 3:39 pm
Well my 1100S motor runs 10.5 now :P
Lillee - 1969 Morris Mini K
PostPosted: Tue Feb 15, 2011 5:04 pm
Mods rock!
My Leyland Workshop Manual in the UK section, puts the 1100s Engine at compression ratios of 8:1, 8.8:1 & 9.75:1 however the Australian Section puts it at 8.6:1. I would suggest the latter is a typo, as there are no factory parts listed in either the UK or Ozzy lists that could give an 8.6:1 compression ratio. Likewise, there are no listings for parts to give 8:1 CR either :roll:
It also lists (in the UK Section) HC Engines having 8.8 or 9.75:1 ratios (go figure) and the LC is the 8:1
PostPosted: Tue Feb 15, 2011 5:11 pm
I have 8.6:1 in a couple of different BMC books, so if it was a typo it was done in 67, 68 and 77 by three different printers.
PostPosted: Tue Feb 15, 2011 5:50 pm
done it many times!
??? :roll:
They fit into a round nose mini as well. :wink:
Have a Nice Day.
PostPosted: Tue Feb 15, 2011 5:55 pm
850man wrote:
done it many times!
??? :roll:
Obviously just. Must need a bit of work on the LHS bonnet methinx. Looks proud.
PostPosted: Tue Feb 15, 2011 6:48 pm
bamnfi wrote:
850man wrote:
done it many times!
??? :roll:
No, they fit right in - Ms Plum has the full 110S setup, no mods to the bonnet or catch at all
'62 Morris 850 (Marion)
'69 Vanden Plas Princess 1300
'71 Wolseley 1300
'74 Austin 1300 Countryman
'94 XJ6 Sport 3.2
'04 Rover 75 CDTi
PostPosted: Tue Feb 15, 2011 6:52 pm
bamnfi wrote:
850man wrote:
done it many times!
??? :roll:
Nope, std bonnet as well. Most Nb cars use the bigger M1100 radiator, no need to modify the bonnet, it just fits.
Have a Nice Day.
PostPosted: Wed Feb 16, 2011 9:11 am
Your kidding! from both pics it looks like it sticks out by an inch or more!
Users browsing this forum: drmini in aust and 92 guests
