It is currently Sat Jul 19, 2025 12:10 pm
Post new topic Reply to topic  [ 41 posts ]  Go to page 1, 2, 3  Next
 Post subject: 1275 cam selection
PostPosted: Sat Feb 19, 2011 8:18 am
what would be a good cam for my 1275 ?
want something with good torque, not worried about top speed,for street use,nothing too wild.
where do i buy from & how much should i expect to pay ?
many thanks in advance
jayson
PostPosted: Sat Feb 19, 2011 8:56 am
RE83 from Graham Russell
PostPosted: Sat Feb 19, 2011 11:33 am
gafmo do you know how much these are ?
has anyone used the cams that karcraft sell ?
PostPosted: Sat Feb 19, 2011 11:42 am
Mods rock!
Karcraft don't do cams anymore, although they are still on their list.
You could also think about a Wade 113 or 140.
http://www.wadecams.com/
PostPosted: Sat Feb 19, 2011 11:54 am
you don't normally "buy" a cam, you send your cam to a cam grinder and they grind the new profile onto it.
GR does a grind for somewhere around $140
To choose a cam, ring your preferred provider and explain what you want to do with your car, and they'll recommend one. In my case, GR is my preferred provider, I ring him and talk about it.
I have an RE83 in my 1275, it's great for low down torque and pulls like a train to my rev limit at 6500.
02 9630 2195 (off by heart :lol: )
PostPosted: Sat Feb 19, 2011 11:58 am
thanks simon i`ll give gr a ring on monday
PostPosted: Sat Feb 19, 2011 12:15 pm
cheers Simon
PostPosted: Sat Feb 19, 2011 12:30 pm
Mods rock!
The published timing figures for the Wade Cams I suggested ^^ are;-
113
Inlet 30 / 65, Lobe Lift 0.262", duration @ 0.050" 212 deg
Exhaust 66 / 30, Lobe Lift 0.262", duration @ 0.050" 212 deg
LSA 107.5 deg
140
Inlet 40 / 70, Lobe Lift 0.296", duration @ 0.050" 238 deg
Exhaust 74 / 41, Lobe Lift 0.297", duration @ 0.050" 238 deg
LSA 106.0 deg
Out of curiousity, what are the published specs on an RE83?
PostPosted: Sat Feb 19, 2011 2:09 pm
Wade cams here in melbourne have a number of good grinds to suit A series engines, give them a call and tell them what you want and they can help you. Most grinds cost around $70.00, far cheper than anyone else.
Have a Nice Day.
PostPosted: Sat Feb 19, 2011 4:00 pm
i have a wade 240
runs very nice not lumpy has a good power curve
easy to tune
W A D E C A M S H A F T S P T Y L T D
A.B.N 62 004 544 996
27 Wells Road, Oakleigh, Vic, 3166
Phone (03)9568 0333 Fax (03) 9568 2633 Email [email protected]
Profile Actuation Make/Model R/Ratio
240 Flat Tappet BMC "A" Series 848 - 1275 In1.2 Ex 1.2
Cam Lift Duration Duration Valve Valve Lift Phase
Adv @050 Clr Lift tdc <)
Intake 283 282 220 0.013 0.3258 061 109.5
Exhaust 283 282 220 0.013 0.3258 041
Timing Timing
Adv @ 0.05
Open Close Open Close
Exhaust 74 28 43.5 -4
Intake 34 68 4 35.5
62 0
Deg Over-lap Deg Over-lap
Max Lift In 106 Atdc Max Lift Ex 113 Btdc
PostPosted: Sat Feb 19, 2011 4:04 pm
dodge wrote:
i have a wade 240
dad has a Wade 240 in his Minor (1275) - they said it was equivalent to a Cooper S cam - though it's been in there 20 years so mightn't have quite as much lift as when it went in
PostPosted: Sat Feb 19, 2011 9:27 pm
wade cam is the only way to go. I have run the 240 in both small bore and 1275's and for a road cam with a good designed head it makes a very torquey motor.
Cam shaft profile is a complicated selection. I have seen identical engines with identical cams, but differences in head design makes a big difference.
With any cam decision get the grind details and compare before deciding.
www.minisprintgt.com
PostPosted: Sun Feb 20, 2011 6:09 am
thanks for all the replies/info
jayson
PostPosted: Sat Feb 26, 2011 5:18 pm
Mods rock!
So with all the people out there who have bought one or had one ground, no one knows the specs? Don't you get a data sheet? How do you know how to time it in?
PostPosted: Sat Feb 26, 2011 6:10 pm
That is very inexpensive..
