It is currently Sat Jul 19, 2025 3:49 am
Post new topic Reply to topic  [ 39 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Wed Feb 23, 2011 6:07 am
Don't over estimate the effect tilting the engine and/or carb has - if a few degrees mattered (even that last pic) then cars wouldn't go up and down hills.....
PostPosted: Wed Feb 23, 2011 8:33 am
Here's mine:
From inside you can't tell that there is a box. So much more simpler...
PostPosted: Wed Feb 23, 2011 9:52 am
But what does it look like form the inside?
2008 Prado GXL
PostPosted: Wed Feb 23, 2011 1:20 pm
You have to have a discerning eye to figure out that it's 1inch further back than usual
PostPosted: Wed Feb 23, 2011 1:24 pm
You can't tell me that turning your engine, modifying engine steadies, gearbox mounts, engine mounts, radiator mod to fit, even having front of the sump protrude further down than it is now is better than just cutting a square hole in the firewall?
It is reversible to a certain degree. IF it aint an S or collectable car, then why not?
PostPosted: Wed Feb 23, 2011 2:34 pm
I like your steering wheel, is that a Motalita? How'd you get the centre button like that, ooh thread hijack, oh wait..this is my thread :D
2008 Prado GXL
PostPosted: Wed Feb 23, 2011 3:10 pm
I like my steering wheel too lol. Have tried numerous wheels, this one feels right for a mini.
Yes it's a moto lita. The horn push: had to "modify" a volvo horn push that originally came with another moto lita wheel that I had. Now it's a push fit.
PostPosted: Wed Feb 23, 2011 4:14 pm
Mods rock!
Tilting the engine forward up to about 20 - 25 mm is dead easy, and reversable, if (as you have) a rod change set up. The biggest 'hassel' maybe the exhaust. Any carb fitted will need to be roughly at the same 'level' as it was intended to be, but does not need to be accurate in any way. A tilt forward of up to 15 mm would not need any mods in his dept.
Won't bother the cooling system, other than to make it easier to fill the radiator, will also improve the lubrication system as the oil pick up is in the front and so will be 'deeper'.
Rover move the entire engine forward with longer steadys and different drillings in the subframe.
PostPosted: Wed Feb 23, 2011 6:40 pm
The MiniMatics were 20mm? further forward too.
PostPosted: Wed Feb 23, 2011 8:20 pm
Lillee wrote:
Your tacho isn't out of a Fiat 124 sports? :wink:
Looking good - or is that digital camera trickery? :lol:
PostPosted: Thu Feb 24, 2011 8:28 am
No that's a brand new Smiths tacho with a smiths pod. I spent $2000 on the interior overhaul last year so hopefully it's not camera trickery!
PostPosted: Thu Feb 24, 2011 10:37 am
Lillee wrote:
Very sweet interior 8)
Interesting long stalks on the switches?
Also very clever with the "horn" button. :P
:oops: Sorry about the hi jack Fat Boy Dave. Just had to comment. :roll:
PostPosted: Thu Feb 24, 2011 10:58 am
yes looking good Chong.
100% Pure A Series Turbo
PostPosted: Thu Feb 24, 2011 11:03 am
Dave, I think your thread went that way --->
:roll:
PostPosted: Thu Feb 24, 2011 11:05 am
Cheers Grant!
MGRocket: they are period rally accessories!! Switch extensions are for cars fitted with 5 point harnesses. Once you're strapped in, there aint no way to reach the lights or whipers... GR himself gave me those 8)
http://www.minis.com.au/minis/catalog/p ... cts_id=633
