It is currently Mon Jul 21, 2025 5:54 pm
PostPosted: Mon Mar 07, 2011 2:05 pm
It might also be a problem with your choke. Make sure it's not stuck open. The first stage of an SU choke is a fast idle, the second lowers the jet to richen the mixture. I had a problem with the jet staying open even with the choke in all the way.
Reach under the carby and give the jet (which sits just below the adjusting nut) a push up. It shouldn't move, but if it's stuck open you should be able to move it up a little.
PostPosted: Mon Mar 07, 2011 7:29 pm
I'm thinking Choke also. Is it connected and or do you have it spung closed (choked)
PostPosted: Mon Mar 07, 2011 8:50 pm
Fiji wrote:
so it was raining while you you were driving or just now ?
go back to this question..... take the distributor cap off and check for water
When I was running a pulsar distributor, it'd drive OK in the rain as the water would run down the shaft and into the base, then when I parked it the distributor would heat up, the water would evaporate and then condense in the cap and then it wouldn't start....
PostPosted: Mon Mar 07, 2011 10:05 pm
76van wrote:
no wasn`t raining when i was driving.
made the mixture richer,just made it worse
moved dissy either way,no improvement
thinking maybe wrong needle in carby
spark plugs.. bet they are black & sooty.
PostPosted: Mon Mar 07, 2011 10:36 pm
I check the timing by ear (once its running of course), just a tube from the air intake to my ear, and I do it like that, unconventional maybe, but it works fantastic for me.
Cheers, Sam
PostPosted: Tue Mar 08, 2011 2:28 pm
bamnfi wrote:
And here I was thinking he had lost his engine :shock:
It's always in the last place you look!
PostPosted: Tue Mar 08, 2011 5:49 pm
I was thinking he should look in the boot - he may have a VW
David L
PostPosted: Wed Mar 09, 2011 6:52 am
yep black sooty plugs & turns out i had a #4 needle in the carby.
new plugs & #7 needle & all seems good.
thanks for all the help,greatly appreciated.
jayson
Users browsing this forum: fuzzy-hair-man, ken@miniauto and 71 guests
