It is currently Sat Jun 28, 2025 3:02 am
Post new topic Reply to topic  [ 49 posts ]  Go to page Previous  1, 2, 3, 4  Next
From your experiences which suspension should I go for? Cost and road performance are my criteria.
Option 1 (Coils lowered) 3%  3%  [ 1 ]
Option 2 (Coils standard) 0%  0%  [ 0 ]
Option 3 (rubber, hi lows conversion) 35%  35%  [ 11 ]
Option 4 (Hydrolastic) 61%  61%  [ 19 ]
Total votes : 31
PostPosted: Sat Mar 12, 2011 10:04 pm
1018cc wrote:
Believe it or not I pumped mine up to standard height and it sits level :shock: :P Rides better too.....
Funny, I have been saying that for a while now. :lol:
PostPosted: Sat Mar 12, 2011 10:09 pm
Give Ash some flowers Nick .
If I remember tomorrow I will get it out of the garage and take a picture for people (I'm sure there would be those that wouldn't believe me). No trickery either, standard length rods, standard bags all 'round, standard 44 year old rear helper springs :wink:
PostPosted: Sat Mar 12, 2011 10:10 pm
This space for rent
Mine's the same 8)
PostPosted: Sat Mar 12, 2011 10:18 pm
sgc wrote:
Mine's the same 8)
And mine. But it's only 41 years old this month... 8)
PostPosted: Sat Mar 12, 2011 10:19 pm
41 years young!
You're so square
Baby I don't care
PostPosted: Sat Mar 12, 2011 10:51 pm
amazing isn't it - use it the way it was designed and it works! A set of longer bottom arms doesn't go astray though
I've always kept mine at standard height, rides better than the Prelude I've been driving the last couple of months
PostPosted: Sun Mar 13, 2011 8:38 am
1018cc, would you mind taking a measurement from the centre of the wheel to the bottom of the flare? I think this is where they used to measure from, ( as per the workshop manual ,someone please correct me if i'm wrong).without going and digging out a book, the standard height is about 13.1/4', is this correct,
Just measured mine (hydro ) and it sits at 11' .
PostPosted: Sun Mar 13, 2011 8:44 am
Before someone else picks you up on it,
13 1/4' is a pretty huge gap :P
13 1/4" is more like it ;)
You're so square
Baby I don't care
PostPosted: Sun Mar 13, 2011 8:50 am
Thanks Adam, as soon as i re-read it i noticed my mistake,so a lollipop for you for being the first to spot it .
Colin.
PostPosted: Sun Mar 13, 2011 8:53 am
With a Mini there is not a lot of room for suspension travel. If the car is sitting 2" low it will already be on the bump rubbers and the suspension will not be working.
They really need some suspension travel to work properly.
If you are going to ride on the bump rubbers you may as well not run springs at all. :lol:
PostPosted: Sun Mar 13, 2011 9:10 am
I see exactly what your saying Morris, and i have been going to have a good look at my Hydro for a while now, as it is a tad down on the right hand side, just gotta get off my butt and do something about it.
And on the subject of Hydro, i have since found a bloke, that lives very, very close to me that tells me he has 2 genuine hydro pumps, i'm yet to see them , but i'm on his case let me tell you.
As for the fluid, ( now i know this has probably been covered numerous times before), people have said to use Glycol and de-mineralised water, so to get this correct, do they mean straight Glycol ,or radiator inhibitor?, or has sombody else used something else, if so what would people recommend?
PostPosted: Sun Mar 13, 2011 9:13 am
I use premixed coolant.
A factory hydro pump is a great thing but a home made one works just as well.
PostPosted: Sun Mar 13, 2011 10:01 am
Out of curiosity I just measured mine. 12" right, 12 1/2" left. Curiously though, the front is level - 10 3/4" both sides. I s'pose I should really roll it out onto level ground to check it properly. There's a very slight slope across where it's currently parked which could upset the balance a tad. :P
PostPosted: Sun Mar 13, 2011 10:02 am
I use straight antifreeze (castrol something-or-other that's 98% glycol)
PostPosted: Sun Mar 13, 2011 2:55 pm
I use 50/50 Ethylene glycol concentrate (Nulon) and distilled water.
This is pretty much the spec for Penrite's hydro fluid when they sold it here.
Users browsing this forum: Bing [Bot] and 79 guests
