It is currently Sat Jul 19, 2025 6:46 pm
Post new topic Reply to topic  [ 219 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 15  Next
PostPosted: Sun May 01, 2011 9:28 pm
michaelb wrote:
work out how to fit the trigger wheel for the Megajolt ignition.
that's going to be a pain with that pulley...
when it comes to the coil pack, chuck away the ford one - try one off a Hyundai Excel instead, looks much neater
PostPosted: Sun May 01, 2011 9:36 pm
You need the rite Alt also :lol:
What is that :?:
PostPosted: Sun May 01, 2011 10:37 pm
I found this alt worked a treat
http://cgi.ebay.com.au/ALTERNATOR-MINI- ... 3cb246b029
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
PostPosted: Sun May 01, 2011 10:44 pm
What is that :?:
alternator makes no difference :? just whatever one works. I have a single multi-v belt so got an alternator with a pulley that suits... it's off a subaru of some sort. I modified the mini alternator bracket to mount the alternator lower down. I cut the hyundai coil bracket down and welded it to the mini alternator bracket... nothing special
PostPosted: Mon May 02, 2011 4:44 pm
naa ford one looks good :)
PostPosted: Mon May 02, 2011 5:04 pm
I dunno Ben.... that big lump behind the intercooler is gonna restrict the air going through it :lol:
PostPosted: Mon May 02, 2011 9:17 pm
Started to mark out to fit the trigger wheel for the ignition.
Fitted the sensor bracket, found TDC and marked the pulley and trigger wheel ready to drill and tap for attaching bolts.
Fitted the water pump, speedo drive and radiator/engine mounting bracket.
Discovered a problem with the flywheel which has been machined and lightened and now has no timing marks. The marks I thought were for timing do not line up with TDC? :?
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Mon May 02, 2011 9:19 pm
So Ben,
Have you had your engine running yet
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Mon May 02, 2011 9:27 pm
doesn't matter... you can mark it again. Get your timing wheel and dial indicator out again. Dial indicator on #1 piston and find a few thou either side of the top and go half way between them on the timing wheel. You only need one mark at TDC, don't need the 5/10/15 degree marks
the megajolt software has adjustment in it to take up anything from the sensor bracket position
PostPosted: Mon May 02, 2011 9:36 pm
Thanks Simon, I had similar thought.
also noticed the key in the crank is at 12 o'clock when engine is at TDC
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Mon May 02, 2011 10:02 pm
yeah it is, but too hard to be exact with it - it can look right, but be 5 degrees either way
when I time my engine to make sure the advance in the ignition is correct at the crank, I have an ignition map that is 10 degrees in all cells. You can rev the motor all you want, and the timing mark won't move.
I load that up and shoot the timing light at the timing mark on the flywheel. Last time I did it, I couldn't find the timing mark. The bugger was hiding right under the pointer on the timing cover!
So long as you know what your mark is in relation to TDC, you can do the same
PostPosted: Mon May 02, 2011 10:49 pm
So my job tomorrow night is to mark the flywheel with a new TDC marker
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Wed May 04, 2011 9:30 pm
Update.
I have marked the flywheel and reassembled.
Fitted the trigger wheel to the pulley and after a number of fine adjustments it now has minimal run out in relation to the sensor.
Fitted onto the engine
added the fan to check for clearance
Now I need to complete drilling and tapping a few more holes in the pulley and locktite the screws and tighten up the pulley nut.
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Thu May 05, 2011 10:54 pm
finished fitting the trigger wheel
and managed to get the gap consistant
Then fitted the radiator but have a problem with the bottom support bracket, which will need modifying
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Sat May 07, 2011 9:39 am
Did a trial fit of the supercharger and extractors.
Very please so far but it will be a tight fit in the engine bay.
Not sure how to reach the manifold nuts when it is in the car and I needed to loosen the supercharger to get the belt to fit on the pulley as it is very tight.
1969 Cooper "S"
1967 Mini Deluxe
