It is currently Thu Aug 21, 2025 5:04 pm
Post new topic Reply to topic  [ 58 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Spray on
PostPosted: Thu May 12, 2011 7:29 am
Powder coating can be applied in 3 ways,
Electrically polarise each item and they electrically attach before mechanically locking when the powder is melted on the part in an oven.
Fluidised bed where the part is preheated and submersed in a mist of powder (normally a bath) The powder melts on contact with the hot part
Premelt Powder where the powder is melted as it leaves the gun and cools when it hits the object.
At home the easiest way is fluidised bed, gear for parts. Commercially it's Electrically and some fluidised, Premelt is very uncommon due to performance of coat adhesion and finish.
If you want a special finish with long term life go for a metal spray (yes it's actually 100% metal) or ceramic.
PostPosted: Thu May 12, 2011 10:00 am
Hunter2 wrote:
Bought a new rear subframe for the 1980 Mini, had it powder coated and installed it in 1999. In 2003, stripped the Mini for major resto/mod and...powder coat came off the rear subframe in sheets with a garden hose.
Sand blasted the sub frame to bare metal, primed and painted automotive black...8 years later still good!
In my view powder coating is only of limited use in an automotive application, heat/engine/exhaust/brakes, cold/snow/salt/deicers, rain/sand/road grit/wind, oil/brake fluid/fuels, etc....not your living room ornament.
i got offered to have my subframes galvanised, would that be worth it?
PostPosted: Thu May 12, 2011 10:20 am
No.
Australian subframes don't suffer from the rust problems that the overseas places do. Have you ever seen a badly rusted subframe in Australia? (I have, it was a very modified one fitted to a car trailer)
I would just paint it properly and let it last another 40 years!
PostPosted: Thu May 12, 2011 11:58 am
No.
but it wouldn't hurt would it? it's just that the guy offered to do both subframes for 80 bucks apiece with some other chassis work, and i'm a little pushed for time at home to paint them nicely atm.
PostPosted: Thu May 12, 2011 12:13 pm
It could hurt. It depends on the temperature of the gal process. I have heard of problems with distortion with other things.
Talk to the guy and see what he says. He will have a better idea.
PostPosted: Thu May 12, 2011 12:18 pm
okay will do. i did hear about warping in the heat, but the guy works for a pretty top notch bodywork/painting workshop so i would *hope* that he knows what he is doing.. :?
PostPosted: Thu May 12, 2011 12:24 pm
If he stuffs it up remember it is only a subframe. You can always get another one easily enough. :lol:
PostPosted: Thu May 12, 2011 12:37 pm
No.
Prob about the same cost as powdercoating!
PostPosted: Thu May 12, 2011 12:41 pm
very true haha
i suppose, i figured galvanising would be 'better' though..
had my wheels powdercoated, hopefully they stay looking good.
didn't mean to hijack thread lockie :lol:
PostPosted: Thu May 12, 2011 12:46 pm
I had every piece of suspension and brakes powdercoated in 2002, still lookin good.
PostPosted: Thu May 12, 2011 1:11 pm
I reckon you should have taken the subframe back to the powdercoaters for a warranty job - their prep must've been to blame...
PostPosted: Thu May 12, 2011 1:17 pm
I have never been happy with powdercoat on anything. It is the most over rated stuff around.
I prefer real paint and not electrically applied oven baked dust.
PostPosted: Thu May 12, 2011 1:22 pm
For things like subframes I reckon that a properly applied Kill Rust system is hard to beat. The epoxy top coat cures hard and glossy (or matt if that's what you want)
David L
PostPosted: Thu May 12, 2011 3:36 pm
No.
correct there hanra. Powdercoating in this case would be slightly cheaper than clutch monkeys gal.
PostPosted: Thu May 12, 2011 3:37 pm
how often does the car get used? :lol:
Users browsing this forum: No registered users and 140 guests
