It is currently Fri Aug 08, 2025 6:37 pm
PostPosted: Fri May 20, 2011 5:39 pm
Just wondering if you can still use the cable you have by bending a loop into the end, even if just until u find the right cable.
Only problem is if that doesn't work the cables ruined. (can't sell or return it then)
PostPosted: Fri May 20, 2011 7:50 pm
I could actually. I could put in a loop and then clamp the ends.
It'll get it going. Perhaps I might come across something this weekend (at mini expo).
1966 Morris Mini Minor Saloon (Dot) - 1275 Auto - Mongrel
1968 Morris Mini Van (Ivan) - 998 Auto - Mongrel
1968 Morris Mini.Matic (George) - Original
1968 Morris Mini.Matic (Charlie) - Original
PostPosted: Fri May 20, 2011 7:58 pm
You just need to make a clamp that will hold the cable to the rod.
Everyone start thinking...
PostPosted: Fri May 20, 2011 8:11 pm
I am sure I have the correct cable. I will bring it to the Minishow and give it to you. For free. Because I am a nice bloke. :wink:
Have a Nice Day.
PostPosted: Fri May 20, 2011 8:14 pm
Appreciated.
Just look for the Red 68AUTO.
PostPosted: Fri May 20, 2011 9:54 pm
Hijack time!
On the clubby heaters (the black plastic in-car jobs), how does the heat adjuster (hot-cold) connect to the heater? I think it attaches at the back of the heater somewhere, but I can't see where. Anyone have a photo or a very good description?
PostPosted: Fri May 20, 2011 9:58 pm
It attaches to the tap on the heater hose.
PostPosted: Sun May 22, 2011 8:55 pm
Back to the original post.
Thanks David for the cable. You are a good bloke. Now I know how to describe that heater cable. It's the pig tailed one.
Much appreciated. I will see you at the next event.
PostPosted: Mon May 23, 2011 7:27 pm
hey David, chance you have another? I only picked up a heater at the show and missed this thread :P
Thanks for putting in the hard work for me JTR :P
'63 850/1100 + more cooper goodies
PostPosted: Mon May 23, 2011 10:04 pm
This space for rent
850man wrote:
The cable you require is unique to the under bonnet type heater and is not available new.
Aaaactually that's not entirely correct. A couple of years ago I was looking for one of these and as you say, couldn't find one for sale anywhere. I did manage to find a US-based company which makes them up though, and ordered one from them. It's perfect :D (although the rivet-counters will complain that the knob is wrong, but I don't care - it works :) )
JTR / Callin - let me know if you want me to dig around for the name of the company I used...
PostPosted: Tue May 24, 2011 3:10 pm
There is a company in Sydney that can make them.
http://www.conwire.com.au/
Unit 10 / 14 Sheridan Close,
Milperra NSW Australia 2214
Phone: 02 9774 2155
Fax: 02 9774 2166
http://www.conwire.com.au/may07_files/page0015.html
PostPosted: Wed May 25, 2011 1:22 pm
This space for rent
There you go - use the mob Morris mentioned, much easier than stuffing around with the U.S...
