It is currently Sat Aug 23, 2025 6:58 pm
 Post subject: Heater Diagrams
PostPosted: Thu Jun 09, 2011 12:30 pm
I pull the heater apart about 2 years ago to overhaul it and repair the core- now I can't work out how it goes back together :?
Anyone know of exploded diagrams ?
David L
PostPosted: Thu Jun 09, 2011 12:53 pm
Mods rock!
What type of heater was it? (maybe a pic of what you have)
PostPosted: Thu Jun 09, 2011 2:42 pm
I'll organise a photo tomorrow
David L
PostPosted: Thu Jun 09, 2011 4:30 pm
Not the best, but a start!
Probably the metal bodied one?
http://www.somerfordmini.co.uk/eshop/in ... page&id=98
:P
Sir Alec! we are not worthy!
PostPosted: Thu Jun 09, 2011 5:13 pm
Looks like the plastic bodied on on the left - can't see much from that diagram though
David L
PostPosted: Thu Jun 09, 2011 5:28 pm
I can't find the right one for the plastic heater that was fitted to the Aus Mk2 Cooper S but I have this one that is similar except for the flap controls.
Link to the full page version... http://i207.photobucket.com/albums/bb2/britishmotorcorporation/heater01.jpg
PostPosted: Thu Jun 09, 2011 5:37 pm
Mk2 S heater...
PostPosted: Thu Jun 09, 2011 5:43 pm
Hmmmm....thanks for the effort Morris but not quite right - think there is a bullet shaped cone on one end and I'm sure the small pipes on the core are on the left hand side looking at it - tap control it there also - Home at the weekend and I'll dig it all out and get serious with it. The model I have also has separate controls on a plate hanging under the parcel shelf near the steering column - (looking for one of those as well)
David L
PostPosted: Thu Jun 09, 2011 5:48 pm
Mods rock!
Ah, Ozzy Clubbie heater!
These are listed in the parts book, but no diagram. There's not much to it. I'm sure if you sat down for 15 minutes with a cuppa and a smoke, you'd soon figure it.
PostPosted: Thu Jun 09, 2011 5:57 pm
Mods rock!
If the tap is cactus, use one of these with a longer cable, they are way cheaper than the original
http://www.minisport.com.au/prod210.htm
It mount straight to the cylinder head in place of the elbow over no. 4 cylinder.
PostPosted: Fri Jun 10, 2011 12:34 pm
Hi
I am looking for an Australian clubman heater in very good condition for a restoration of a GT.
Can any body help?
PostPosted: Fri Jun 10, 2011 1:45 pm
I'll be replacing my clubby tap soon (or just installing - there's no tap at the moment) . I was just going to use one of these:
http://www.ebay.com.au/itm/Heater-Valve ... 45f9d5712a
This might require a little time for fitting and adjustment, but I'm stubborn and usually get things working.
PostPosted: Fri Jun 10, 2011 6:13 pm
For a cooper s heater I wonder if you could have the shutter connected to the valve via cable? You could put the valve just before the heater radiator so when one closes the shutter it also closes the valve from hot water circulation.
Mini's I grew up with
Slot car couch
PostPosted: Sun Jun 12, 2011 5:28 pm
Mods rock!
Good price but they are for 5/8"hose. The stock Ozzy Mini's were all 1/2", Do they have them in this size?
Users browsing this forum: No registered users and 125 guests
