It is currently Sun Aug 17, 2025 12:13 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 250, 251, 252, 253, 254, 255, 256 ... 568  Next
PostPosted: Sun Jun 19, 2011 11:09 pm
adamstuart wrote:
some bits of RHS and a few G Clamps.
Sounds like a folder to me. Just get some LEVERAGE on it :wink:
PostPosted: Mon Jun 20, 2011 9:17 am
Ordered some felt backed Hardura in light blue for the lining the doors,rear pockets and parcel shelves.
David L
PostPosted: Mon Jun 20, 2011 6:27 pm
Got some more work done on Sunday arvo!
Pick up... 9th July 2011 :D
PostPosted: Mon Jun 20, 2011 7:42 pm
That is looking sweet. :D
PostPosted: Mon Jun 20, 2011 8:15 pm
Show off .... Looks sick
PostPosted: Mon Jun 20, 2011 8:30 pm
Put half the floors in KhanaMoke
You're so square
Baby I don't care
PostPosted: Mon Jun 20, 2011 9:17 pm
Filled the new engine up with oil and then tried to turn it over by connecting a battery to the starter motor but discovered the new starter is tight and wont turn :shock: :? :(
Lucky I checked prior to taking engine over to GR.
The starter motor might just need adjusting, will pull it out tommorrow night and investigate.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Fri Jun 24, 2011 2:30 pm
Pulled the engine out yesterdy, first time i've pulled engine out this way, i have only lifted the body off engine and subframe previously. Went quite well, caught on bits a couple times but pretty straight forward.
Now to tart up the engine bay.
I am going to grind off the dodgy plate someone has welded on just below the brake and clutch master cylinders. (it held brake/clutch lines and engine steady i think)
Does anyone know if this is something i can purchase to replace? or is it something i need to fabricate?
PostPosted: Fri Jun 24, 2011 5:12 pm
Can you provide a photo?
There is a plate which is spot welded on at this point,
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Fri Jun 24, 2011 8:16 pm
Drove the mini van to work and parked in the car park, under cover, while I am on leave for the next 4 weeks. :)
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Fri Jun 24, 2011 9:28 pm
I felt the need for a GOOD pie..
So I drove up to PITS via Berowra Waters ferry and back through Galston Gorge. No traffic either.:P :P 1412 stroker is going well.8)
PostPosted: Sat Jun 25, 2011 2:48 pm
Drove the twinky moke on the road (yeah.. it might not be registered)
Twinky motor, is absolutely nuts.
wow.
and then I...
...sold the motor. :cry:
You're so square
Baby I don't care
PostPosted: Sat Jun 25, 2011 3:34 pm
Milatsmadmini
wow.
and then I...
:cry: :cry: :cry: :cry:
PostPosted: Sat Jun 25, 2011 3:50 pm
it's okay matt
There will always be photo memories
You can see the carbies cheekily poking out the front grille!
You're so square
Baby I don't care
PostPosted: Sat Jun 25, 2011 5:03 pm
adamstuart wrote:
it's okay matt
What The #uck??? Y???
DVS K
Toad the Moke
Brutus the Ute
Mean Monster
Purple People Eater
Users browsing this forum: No registered users and 246 guests
