It is currently Mon Aug 18, 2025 2:35 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 254, 255, 256, 257, 258, 259, 260 ... 568  Next
PostPosted: Fri Jul 01, 2011 8:30 pm
I just linish .020" off the flat face. I can't turn them on my lathe as they are hardened at the 3 lugs.
PostPosted: Sat Jul 02, 2011 9:49 am
Yesterday actually- little dash globes arrived in the mail so added them to the wiring - How do you get those bleeding holders to stay in place? - they are hard to get into the holes in the first place (thought it was due to being new ) but once in they pop out again at the slightest provacation :evil:
David L
PostPosted: Sat Jul 02, 2011 7:35 pm
Put the subframes in and fixed the hydro on the best matic i've ever seen..
Good fun ;)
You're so square
Baby I don't care
PostPosted: Sat Jul 02, 2011 7:39 pm
Ordered some adj tiebars from Minispares for the van... :wink:
[edit] I should have bought them here from Karcraft, with Minispares' UPS ripoof freight cost, this would have been cheaper. :cry:
Last edited by drmini in aust on Sun Jul 03, 2011 8:26 am, edited 1 time in total.
PostPosted: Sat Jul 02, 2011 7:44 pm
Does this mean you're making a start on it Kev?
Painted by friday?
You're so square
Baby I don't care
PostPosted: Sat Jul 02, 2011 8:15 pm
got some rims :D
PostPosted: Sat Jul 02, 2011 8:55 pm
Painted by friday?
I'm getting bits ready for my impending retirement from the fabrication biz. 1 month to go... :P
I've just started doing up the 2 hydro subbies for the van.
PostPosted: Sat Jul 02, 2011 10:35 pm
oil change and change oil filter to spin on
PostPosted: Sun Jul 03, 2011 2:22 am
Milatsmadmini
Painted by friday?
i no where a rust free shell is... just sayin is all... :wink:
PostPosted: Sun Jul 03, 2011 12:53 pm
Finally got the spacer/belt retainer finished as per the good Dr Mini Specs...will keep my timing belt safe and sound on the crank pulley.
Fornt View
[/img]Image[img]
Side
[/img]Image[img]
Flat view
[/img]Image[img]
[/img]Image[img]
[/img]Image[img]
Comparison with a 998 oil slinger
[/img]Image[img]
The keyway is being filed in this afternoon and will FINALLY have the motor finished(only been three years!!!)
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Sun Jul 03, 2011 4:56 pm
Finally fixed the ignition? fuel? WTF? fault in Gafmo's van. It was missing, farting, spitting, etc.
After swapping a coil and new plugs and trying a couple of needles, it turned out that the old Top Gun coil lead had had it. All the plug leads (Bosch) are fine.
PostPosted: Sun Jul 03, 2011 6:05 pm
Dropped the ride height by an inch all round.
8)
PostPosted: Sun Jul 03, 2011 9:48 pm
Drove around on 3 cylinders. Found loose cable at the distributor. Drove on 4 cylinders. I think I like 4 cylinders better.
1970 Mini K
PostPosted: Mon Jul 04, 2011 11:07 am
Almost finished rewiring with a universal kit.
Put together home brew security system.
Installed starter button.
Now i need to find a way to neaten up the spaghetti that is my wiring loom.
So... I'm Seifer
PostPosted: Mon Jul 04, 2011 2:24 pm
Sanded surface rust from roof chanels, rusat preventative and a good couple of coats of my favourite undercoat, sanded back and ready for colour.
Re-installed seams.
Wet sand colour coat on touch ups ready for clear.
Wet sanded door colour coat too much, now need to re-paint :oops:
Went and got a new battery.
A good weekend, cant wait till next weekend and get some more work done, i am against the clock now, the baby arrives in 9 days, i hope its late! :lol:
I'm guaranteed to break something every time, but there's nothing like getting under the bonnet and having a go!
Users browsing this forum: No registered users and 300 guests
