It is currently Wed Jul 30, 2025 9:33 am
 Post subject: tube benders
PostPosted: Wed Jul 06, 2011 10:36 am
Hi Everyone, when I start modifying the brake lines on my mini, a lot of the tube benders are for 1/4, 5/16 and 3/8 lines. now I can`t see a problem with it but I just want to comfirm that as the mini`s lines are 3/16, is it ok to use a 1/4 bender ?
Jethro
PostPosted: Wed Jul 06, 2011 11:45 am
Mods rock!
I'll say a cautious maybe. If the actual radius that the bender makes is small (at a guess, I'd say smaller that about 40 mm), then I'd say no.
A nice bender, the correct size that will do the job is less than 30 bucks, so why not get one?
PostPosted: Wed Jul 06, 2011 1:38 pm
Hi GT, there is none in Bundaberg, looked on ebay and saw one for $37 but that one did 1/4, 5/16 and 3/8, that is why I asked the question. Now I have finished an around the house job ( kept the other half happy ) I want to start putting all the stuff I have bought for the mini on the car. Hoping to do booster connection first ( re routing brake lines etc ). I will have another look around and see if I can get a 3/16 bender.
Jethro
 Post subject: bender
PostPosted: Wed Jul 06, 2011 1:59 pm
The size of tube you want to bend is 3/16 internal diameter?? If so that should equate to about a 1/4 external diameter, thus you could used one of those benders. When they sell tube benders they go by the outside diameter of the material and when places sell Bundy tube the sell it by the internal diameter... It can be confusing!
PostPosted: Wed Jul 06, 2011 2:11 pm
Mods rock!
Ah, Brake Pipe Tubing is actually 3/16" OD, but good point all the same wobbles_55.
jethro, I have seen a few recently, not on ebay for around 25 bucks. Let see if I can find them again.
PostPosted: Wed Jul 06, 2011 2:28 pm
Hi wobbles_55, yes I know what you mean on tube sizes, but mine is 3/16 OD as I had already measured my brake lines.
Jethro
PostPosted: Wed Jul 06, 2011 2:37 pm
Mods rock!
Here's a couple I found in a few minutes;-
Lindsay has these, but he's still on holidays (try you local auto tool specialist)
http://www.minis.com.au/minis/catalog/p ... bc265e7b05
I'd double check with Lindsay on this one;-
<EDIT> These guys can do mail order. I have dealt with them before and they are OK.
http://www.vektools.com.au/
Here ya go;-
http://www.vektools.com.au/powerbuilt-d ... -5915.html
and
http://www.vektools.com.au/powerbuilt-d ... -5916.html
PostPosted: Wed Jul 06, 2011 4:20 pm
Thanks GT, I`m having a final look around Bundaberg tomorrow. If I can`t get one, I quite like the look of the last bender you put up for me from vek tools so I will order that one.
many thanks
Jethro
PostPosted: Wed Jul 06, 2011 5:41 pm
Mods rock!
many thanks
Jethro
Best with that.
PM sent.
And yr welcome :wink:
Users browsing this forum: Barkfast and 80 guests
