It is currently Thu Jul 24, 2025 3:26 am
 Post subject: bent front subframe
PostPosted: Sat Jul 23, 2011 4:38 pm
my front subframe is bent and i was wondering what i should do to get it back straight, or if i should just find a bare one and transfer all the bits over,
well here are some pics
cheers, matt
PostPosted: Sat Jul 23, 2011 4:56 pm
If it's not too out of square (measure diagonally from the tower down to the opposite corner, and again on the other side, the measurements should form a cross across the subby, measurements should match if it's square) I would just hang onto it.
If you want to straighten it out, i'd get your biggest shifter, and lever the metal back down into shape.
I had to modify my subframe in a similar fashion to the fit the twinky into the moke.
If it's quite far out of square, just get a new one
People tend to offload them for free quite often
You're so square
Baby I don't care
PostPosted: Sat Jul 23, 2011 4:59 pm
Mods rock!
For that kind of a bend, I'd knock it back out, should be OK.
If say the subframe was twisted, I scrap it and fit another. They are just too damn tuff to un-twist.
PostPosted: Sat Jul 23, 2011 5:00 pm
alright, would the measurements of what is square be in the repair manual?
cheers matt
PostPosted: Sat Jul 23, 2011 5:02 pm
No they won't be
But if the two measurements you take, are the same then the subframe is square
if they are one or two cm different, it should still be okay
You're so square
Baby I don't care
PostPosted: Sat Jul 23, 2011 5:03 pm
adamstuart wrote:
No they won't be
alright mate, thanks for your help
PostPosted: Sat Jul 23, 2011 5:44 pm
Mods rock!
cheers matt
There are subframe alignment measurements in the factory manuals.
PostPosted: Sat Jul 23, 2011 5:48 pm
GT mowog wrote:
cheers matt
+1 just looked
PostPosted: Sat Jul 23, 2011 6:10 pm
CARTER_GT wrote:
GT mowog wrote:
cheers matt
+1 just looked
+1 just looked and then thought I would post my number of posts!
Seriously though, I would replace it rather that repair it, as it may end up straight, it will still look messy and point to a repair.
PostPosted: Sat Jul 23, 2011 6:25 pm
I have posted a wanted, but i will take the subframe out again and take these measurements when i get the chance,
Cheers matt
PostPosted: Sat Jul 23, 2011 10:18 pm
I have a spare frame if you want it. has the other bits on it as well(trumpets, radius arms, tie bars etc...)
Only problem it is in the ACT...
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Thu Jul 28, 2011 1:31 pm
i have found a bare subframe, i need to replace one guard and align the other one and also replace the front apron, so in order to align the panels should i take all the bits off my subframe and put it on the other one, or could i get away with putting the bare subframe on the car and letting it sit on the ground?[/img]
