It is currently Mon Aug 18, 2025 11:02 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 259, 260, 261, 262, 263, 264, 265 ... 568  Next
PostPosted: Sun Jul 24, 2011 10:06 am
changed to a leather gear knob,
tried to install some window winders bought from the UK, don't fit (Bugger)
1970 Cooper'd K
by "Cooper Works"
PostPosted: Sun Jul 24, 2011 12:06 pm
I made another thing for my dashboard yesterday. It's a little housing for the 3 warning lamps that i'll be using. It's designed to fit in one of the spare gauge holes in my Broadspeed dash and will have the face painted black so it matches the rest of the Smiths gauges. The bezel is from an actual Smiths gauge that i had lying about.
It's quite rough at the moment and i need to hit it with some fine sandpaper to clean off the machining marks. But i'm sure you get the idea.
The drawings i did for this thing and the switch panel i showed in a post a few pages back.
- Simon -
PostPosted: Sun Jul 24, 2011 11:11 pm
Hey Simon,
That's spesh work you've done there well done!
1970 Cooper'd K
by "Cooper Works"
PostPosted: Sun Jul 24, 2011 11:21 pm
Molina love your work. but I'm interested what additional switches you are putting In. Also interested in the width of the panel to fit as no over all dimension but everything else is perfect with your tech drawing. I noticed you have a push start in the centre, How you doing the IGN
PostPosted: Mon Jul 25, 2011 8:50 am
The dimensions of my switch panel are identical to the original one. The switches are much closer together, that's how i could fit the extra couple in.
I drew the decorative bezel to show how it will fit in relation to the existing hole in the dash.
I will have 2 spare switches until i install the thermo fan, after which i will have only one spare. I was mainly looking for that aeoplane look whereby you have a massive array of switches so it looks far more technical that it actually is.
Headlights, wipers, fuel pump, interior lights, cooling fan, spare.
There's a key switch for the ignition on the dash near the other gauges. There was already a hole for something that size, so i put it there.
- Simon -
PostPosted: Mon Jul 25, 2011 8:53 am
Just a note... The overall dimension is shown on the drawing. 242mm. The spacing and diameters of the holes are also shown so you can easily determine how wide the actual switch area is.
- Simon -
PostPosted: Mon Jul 25, 2011 9:55 pm
Today I found a set of knuckle joint hidden inside my new brake drums. Just days after a I bought a whole new set. Mini sports thoughtful packaging strikes again :lol:
PostPosted: Wed Jul 27, 2011 8:28 pm
picked up some bits for my LS
PostPosted: Wed Jul 27, 2011 8:32 pm
Opened the bonnet of the clubman to pull the carby off and rebuild it..
Went inside and slept instead 8)
You're so square
Baby I don't care
PostPosted: Wed Jul 27, 2011 9:34 pm
Received my new Revolutions from the UK today,
couldn't wait to get them on.
Very happy...
1970 Cooper'd K
by "Cooper Works"
PostPosted: Wed Jul 27, 2011 9:37 pm
Very happy...
Pic's?
Dicko.
PostPosted: Wed Jul 27, 2011 9:38 pm
ummm stand by, i'm not good at this :?
1970 Cooper'd K
by "Cooper Works"
PostPosted: Wed Jul 27, 2011 9:39 pm
:? I started counting down the 7 days until my follow up with the Surgeon to see if I get the all clear to do more with my back :D :wink: :D and thus get back into work on the mini.
Dicko.
PostPosted: Wed Jul 27, 2011 9:41 pm
Very happy...
Pic's?
Dicko.
There's a rule on another forum I frequent regarding New Stuff: "Pics, or it didn't happen." :)
PostPosted: Wed Jul 27, 2011 9:46 pm
Moved a bed with Morris today. Sorry didn't get pics but it fun
Users browsing this forum: No registered users and 318 guests
