kirby wrote:
Anyway Im at work but have some time to grab the bolts while on lunch, But I dont have the sizes with me.
Does anyone know the sizes of
The upper bump stop bolts, Two screw type. 1/4" UNF NUTS - the bump stop has studs on it
The castor rod bolts Sub-frame end are 1/2" UNF NUTS (I'd suggest 'Conelocks') the Lower Arm end is 5/6" UNF x 1 1/4" Long + Nut + Spring Washer
The lower control arm bolts The inner lower arm pins have a 'stud' already on them. Need a 3/8" UNF Nyloc Nut for these
I assume these are all ny-lock?
Any help would be appreciated, It will save me a trip across town.
Sizes embeded in
RED
